OthersLooking for good 5V relay to switch 230V AC main
2025-02-05 20:45:03
Hello,
I redesegining an old projects where I used this Wemos D1 relay shield:
My model is also SRD-5VDC-SL-C
Rated for 10A 250VAC
This is just one of the worst quality garbage I ever seen. I produced 20 of the same circuit out of that the relay failed in about 18 of them within 2 years.
The relay either stucks (does not turn off even when it clicks) or does the opposite and does not turn on.
I looking for either the same form factor or smaller.
The requirements:
- Be controllable from ESP32/ESP8266 from 3.3V control pin
- Turn on 230V AC home appliances up to 10A
- Good quality and reliable
- Huge plus if I can order it from the LCSC store
- Form factor either the same as the relay board on the picture or smaller (space does matter)
Thanks a lot :)
Popular Posts
More
