OthersComponent matching failures when ordering EasyEDA to JLCPCB
2024-08-12 00:35:56
I'm using components that are all in the JLC library, but some of them are not recognized and I have to match them up in the ordering process, one of the components even has 3 uses recognized and 1 use not recognized (C27592).  Is there some trick to make it start recognizing all the parts correctly?  They do all have the correct C numbers.  The problem seems to be getting worse over time too with more and more components no longer being recognized, but using the C number from the schematic to fix during ordering always works.
This problem does happen with both one-click and manually exporting and loading the files.
