PCBHow a connector (a 40 pin) can be mirrored?
2025-07-01 07:42:32
Hi,
How a connector (a 40 pin) can be mirrored? This is written in an older forum:
"UserSupport 2 years ago
hi
EasyEDA Std deosn't support mirror the footprint
but you can mirror it at EasyEDA Pro v1.9 soon"
I have installed pro version, but only "Flip to Opposite Side" is possible, what is the same I guess as the normal layer change. Anyway I tried it and rotate, etc., but the connector will never be with correct PIN numbering (correctly mirrored, to be able to push on the host connector). So basically I would like a proper connection to a Raspberry Pi, how can this be solved properly, without "hacking" around with silk layers, etc.? Thank you in advance!
