SchematicHow to separate net names before and after decoupling capacitors in EasyEDA without merging?
2025-04-22 14:36:59
Hİ
I’m using two decoupling capacitors (10nF + 100nF) in parallel between 5V and GND to provide local filtering, placed before each sensor in the circuit.
I want the power to pass through the capacitors first, and then go to the sensor’s VDD pin — with the net name before the capacitors as 5V
, and the name after the capacitors as VDD_xx
However, EasyEDA does not allow this. It forces both nets to be merged, treating them as a single net.
I don’t want to use a 0Ω resistor, because I need the capacitors to be as close as possible to the sensor pins without any additional components.
How can I make EasyEDA accept different net names before and after the capacitors, without forcing a net merge?
