SimulationProblems with my Oscillator Board running simulation
2024-11-06 16:59:28
Hello all. My name is Jayson -
I am not able to successfully run a simulation of my circuit before purchasing again via Easy EDA.
The circuit is for raw solar which will be 16-22VOC. So the VOC will split and enter my Oscillator board and
exit with -18v60hz on two terminals -sine wave aswell.
The process is computed with a CD4047be IC.
Most of the power from the panel is delivered to the center channel of the transformer while the osc board with its power will send -18v60hzsin to the (2) outer terminals of the transformer
thus the coil of the secondary will transduce and create 120vacsingle60hz on the other side.
alot of the process depends on the breaker, and the transformer, however the board is in the middle and very important.
here is the oscboard component layout
Yes, somehow I have an LC filter on the end of both Q. for sin wave !!!!
Anyway i have some error list on the simulation...
I really want this to work...I have a 3d image here....
