SchematicEasyEDA Pro Reuse Blocks PCB?
2024-04-27 16:55:12
Hi EasyEDAers,
New EasyEDA Pro User here, go easy on me 😉
I recently discovered the Reuse Blocks in EasyEDA Pro and so far they've been great. However, I've been trying to find out if this feature expands to PCB layout as well.
I noticed when you create a new Reuse Block, 3 files are created (with as the name of the block/project):
-"" Multiplexing block: Allows pin assignment/layout for block usage in other schematics
-"P1." Main schematic: Where you create the actual schematic and place devices inside the block
"" PCB file: ???
This file doesn't seem to have any interface with the main schematic file, so you can't as far as I can tell place devices you've made in that file and lay out/route as you would a normal PCB project. Unlike a normal project, neither of the schematics also have the "generate/update PCB" button so I don't see a way to make them connect.
The ability to lay out a block PCB with the components you've already made, route traces, and label with silkscreens seems invaluable to me. There very well may be a way to do this that I'm missing, I don't see why the empty PCB file would just be there for no real reason. If there is a way to go about this I would really appreciate the help.
Thanks in advance!
File heirarchy, including mysterious PCB file
