PCBUnderstanding Net labels and Design Rules for efficient auto-routing.
2025-02-12 23:13:24
Hello,
I’m new to EasyEDA and trying to understand net labels and design rules for efficient auto-routing.
  • 12V comes from the barrel jack and goes through the fuse, diode, and capacitors before reaching the terminal block.
  • I labeled +12V between the fuse and barrel jack, expecting it to apply to the entire 12V net.
  • However, in the PCB layout, only the section before the fuse is recognized as 12V.
  • I want all 12V traces to be thicker using auto-route, but currently, I have to manually adjust the rest.
Do I need to label +12V before the fuse, after the fuse, and after the diode separately?
Or is there a better way to ensure all 12V traces are recognized as one for auto-routing?
Thanks for your help!
