ST7789 HALLOWEEN DISPLAY
PROST7789 HALLOWEEN DISPLAY
1.1k
🎃Halloween Electronics Contest
Reproduction cost: $5
Creation time:2025-10-27 07:58:54Update time:2025-10-27 08:38:05
Video link:
Result Video
Project introduction:
This project is a custom breakout PCB for the ST7789 TFT display, specifically designed to create a spooky Halloween decoration! 🎃
Using an ESP32-C3 Mini microcontroller, this display will show a frightening ghost face animation. This design is perfect for placing in a dark area. When activated, the facial animation looks very realistic and startling, as if a real ghost is watching.
This PCB simplifies the connection between the ST7789 display and the microcontroller, and includes the backlight control circuitry.
Project function:
  • Display Animation: The main function is to run a spooky face animation for a Halloween theme on the ST7789 display.
  • ESP32-C3 Controller: The project is fully programmed and controlled by an ESP32-C3 Mini.
  • Breakout Board: This PCB serves as a clean breakout board for the ST7789 display's pins.
  • Backlight Control: The schematic includes a transistor (J3Y) that allows the display's backlight to be controlled (turned on/off) via the BLK pin on the H1 header.
Project Parameters:
  • Microcontroller: ESP32-C3 Mini
  • Display: ST7789 Display (e.g., 1.54 inch, 240x240 pixels)
  • Interface: SPI (Serial Peripheral Interface)
  • Operating Voltage: 3.3V
  • Main Components (PCB): ST7789 (U1), J3Y Transistor (U2), Resistors, Capacitors.
Software code:
All source code, required libraries, and a complete tutorial for programming your ESP32-C3 can be found in the following GitHub repository:
https://github.com/pajrigithub/Code-TikTok/tree/main/File%20Code/Halloween
