Decode Robot V1
PRODecode Robot V1
Reproduction cost: $200
Creation time:2025-09-20 02:51:37Update time:2025-12-10 08:29:52
These two PCBs were designed for FIRST Tech Challenge. One was supposed to be a color sensor that used an RGB photodiode with op amps to get the purple value (r+b) and the green value, then compare them with a comparator for a digital output. There is also an optoreflector for proximity. The second was supposed to send encoder, camera, LED, and analog sensor all over 1 USB cable, but the USB cable dropped the signal voltage by a lot for some reason..
