CF Card PPIDE for RC2014 public
STDCF Card PPIDE for RC2014 public
Creation time:2022-09-10 19:24:04Update time:2022-09-10 20:21:57
This module is intended to combine the reliability of the parallel port IDE module (https://z80kits.com/shop/rc2014-ide-hard-drive-module/) with the convenience of a Compact Flash socket.
There are some useful notes about the CF socket and the PCB footprint for it here: https://github.com/PickledDog/rc-cfcard
It's worth noting the pin spacing on the CF socket is very tight. This makes it a very hard part to solder. I don't recommend trying unless you're experienced at soldering and you have the right tools (fine tip soldering iron, solder wick to fix any bridges, etc).
Compact Flash Socket: https://www.mouser.com/ProductDetail/200-CFT12501LDRA01SL
PLCC44 Socket: https://www.mouser.com/ProductDetail/575-944424
82C55A PLCC44: https://www.mouser.com/ProductDetail/Renesas-Intersil/CS82C55AZ?qs=cbl4%252BYHJGOGWQO1URD5sZQ%3D%3D
The remaining parts are pretty common. Stephen C Cousins has very helpfully documented many of them here: https://smallcomputercentral.wordpress.com/components/
