Easy_Retic_V3_public
STDEasy_Retic_V3_public
Creation time:2023-01-14 17:38:16Update time:2023-01-14 17:47:48
This was mainly designed to be used with ESPhome and Home Assistant and makes it very easy to intergrate your existing old sprinklers into your Home Assistant setup.  The device will operate 7 x 24vac solenoids which would be master/pump and 6 Stations.  The yaml provided makes it very easy to use as well. The duration of each station can be adjusted by minutes and a program can be triggers from home assistant and it will run right through on it's own. You can also operate it from a push button on the device it self, which is handy if you install it in a Allbro ENL160806P Case so that you can start/stop and run through the stations if you are outside in the garden working on the irrigation or in the garden.
https://www.youtube.com/@SparkyJames
https://jeggleston1981.github.io/easy_reticulation/
