recommended
Pro Edition
free
devices or 10W pads
standardized processes
Std Edition
devices or 1000 pads
STD 4s battery level led indicator
Project tags
CC BY-SA 3.0
License: CC BY-SA 3.0
Mode:
Mode
Editors' pick
Editors' pick
  • 91
  • 0
  • 0
Update time: 2024-12-13 12:35:25
Creation time: 2024-09-24 13:29:57
The battery level indicator works without any problems, you can add it if you want, all parts are SMD.
battery outer template fiber laser engraved,
The indicator consists of 4 levels, but you can increase it, I am adding a link for the 3D printer box, you can download it from here.
Use it after taking security precautions and testing the connections. I'm using it for now.
https://www.thingiverse.com/thing:6774780
1 10uF C1 C0805 1 C3836351
2 SS14 D1 SMA_L4.3-W2.6-LS5.0-RD 1 C2837270
3 E6C0805UYAC1UDA LED1,LED2,LED3,LED4 LED-SMD_0805-R-RD 4 C375452
4 Header-Male-2.54_1x1 P1,P2 HDR-1X1/2.54 2 C81276
5 7002K Q1 SOT-23-3_L3.0-W1.7-P0.95-LS2.9-BR 1 C8548
6 5.1K R1,R2,R4,R5,R6,R7,R8,R10 0805 8 C104384
7 47K R3 0805 1 C317438
8 51K R9 0805 1 C218539
9 43K R11 0805 1 C322423
10 39K R12 0805 1 C340476
11 10K R13,R14,R15,R16,R17 0805 5 C340502
12 0ohm R18 0805 1 C218539
13 680K R19 0805 1 C218539
14 1K R20 0805 1 C218539
15 Button-SMD-4x4x1.7 SW1 SW-SMD_4PIN-L5.20-W5.20 1 C71847
16 TL431 U1,U2,U3,U4 SOT-23(SOT-23-3) 4 C111578
17 5v zenner U5 ZENNER DIODE 1
