OngoingNmea Wreless Battery Monitor
STDNmea Wreless Battery Monitor
425
:MIT License
Creation time:2024-05-08 10:00:19Update time:2024-05-08 10:54:03
Wireless battery charge monitor. It is installed directly on the negative terminal of the battery and has a pin for a regular terminal. To install, you just need to remove the terminal, install the device and return the terminal to the pin; no modifications to the wiring are required. Can send data to nmea network via wifi, compatible with the navmonitor application
CloneAdd to Album
