CompletedParametric Directional Speaker Array
PROParametric Directional Speaker Array
:MIT License
1. Overview
A parametric directional speaker exploits the air’s nonlinear acoustic properties to carry normal audio on an ultrasonic (40 kHz) beam. By amplitude-modulating the carrier with your audio and blasting it through an array of ultrasonic transducers, the system creates a narrow, “flashlight-like” sound beam. Past a few meters, the audible component self-demodulates in the medium itself, so bystanders off-axis hear almost nothing.
2. Key Components
Microcontroller (STM32F103 “Blue Pill”)
Generates a stable 40 kHz PWM carrier on a GPIO pin
Audio Input Stage
PJ-320 3.5 mm jack
Coupling capacitors (0.1 µF) to block DC
Unity-gain resistor network (1 kΩ, 47 kΩ) for level setting
10 kΩ potentiometer (VR1) for user volume control
Amplitude Modulator
LM358 dual op-amp
One section sums carrier + audio, the other creates an adjustable DC offset
100 µF electrolytic caps smooth supply rails and block low-frequency drift
Power & Driver Stage
L293D dual H-bridge to provide push-pull drive at ±18 V (or your chosen ultrasonic drive voltage)
100 µF decoupling at each supply rail
Output resistors (15 Ω–75 Ω) for current limiting and impedance matching
Ultrasonic Transducer Array
Typically Murata MA40S4S or similar 40 kHz piezo discs
Arranged in a line or grid (e.g. 8×2) for beamforming and increased SPL
3. Underlying Science
Parametric Array Principle
In a linear medium, waves pass through unaltered. But air shows nonlinear behavior at high sound pressures.
When you broadcast two close ultrasonic frequencies (e.g. 40 000 Hz ± audio), their interaction in the medium produces a difference frequency equal to the audio.
Effectively, the air acts as the demodulator, so the listener at distance hears only the audible component.
High Directionality
Wavelength λ = c/f ≈ 343 m/s ÷ 40 kHz ≈ 8.6 mm
A loudspeaker array several centimeters across will have a beamwidth on the order of λ/D (D = array aperture), yielding a tight cone (< 10°).
Self-Demodulation Distance
The audible demodulation builds up over a meter or two of path and peaks typically 3–5 m from the source, depending on amplitude and air conditions.
4. Practical Applications
Museum & Gallery Exhibits
Create individual “audio zones” so each exhibit whispers only to the viewer directly in front.
Retail & Advertising
Targeted audio messages over products or display stands without disturbing the whole store.
Industrial & Medical
Non-contact communication in noisy environments, or focused ultrasonic therapy beams that also “speak.”
Assistive Tech
Personal audio channels—e.g. for hearing-assistance booths—without headphones.
Security & Defense
Discreet warning tones or spoken commands delivered as a narrow “sound spotlight.”
By combining standard analog/RF‐style amplitude modulation, a low-cost microcontroller, driver ICs, and off-the-shelf piezo transducers, you get a highly directional speaker system that carries your voice (or music) inside an invisible ultrasonic beam—unlocking novel ways to deliver sound “only where you want it.”
