OngoingTSAL Circuit Diagram
STDTSAL Circuit Diagram
1.9k
Creation time:2021-06-27 05:23:55Update time:2021-07-28 05:06:56
TSAL for a go cart
components:-
1) six white leds which will be covered with red transparent plastic cover or red leds can also be used.
2) 1k ohms, 15 ohms, 2.2 ohms,
two 10k ohms resistor, 5.6k ohms 1watt resistor
3) hf41f/5-hs relay
4) electrolytic capacitors- 22uf 16v & 470uf 16v
5) 10nf ceramic capacitor
6) ne555p timer ic
7) 2n2222a npn transistor
8) rm9003b led driver ic
9) screw connectors
LED driver formula -
i(current through led)=0.6/r
r is the resistance value connected between cs pin and emitter pin of 2n2222a transistor in above circuit diagram.
CloneAdd to Album
