Germanium Buffer
STDGermanium Buffer
Creation time:2023-11-29 15:44:40Update time:2023-11-29 15:52:14
This is a Germanium Buffer for guitar/audio circuits - with a twist!
The component side is for mounting a PNP Germanium Transistor, but you can use the same circuit and replace the PNP with an NPN Germanium Transistor by installing the NPN or the OTHER SIDE of the board! Just make sure you put the leads in correctly! (you can test Germanium Transistors with my Germanium Transistor Testor project - also shared!)
Thats Flexible!
Not Verified.
