Auto Wah
STDAuto Wah
Mode:Schematic/Simulation
Creation time:2024-05-30 13:11:14Update time:2024-05-30 13:41:55
AutoMoWah is an envelope-filter/auto-wah that is essentially a copy of the DOD FX-25, with slight modifications by me, such as a Switch to choose between the Band-pass and Low-pass output.
This circuit uses the LM13700 transconductance IC.
Input signal is split- one going thru a buffer to the LM13700 and the other is amplified and rectified into a dc voltage to provide the signal necessary for the Wah effect.
Two controls set the wah Range and Sensitivity. You can switch between the BandPass or LoPass output signal, which makes it ideal for Guitar or Bass!
Circuit is unverified.
BOM_AutoMoWah_2024-05-29.csv
1
BOM_AutoMoWah_2024-05-29.pdf
Gerber_PCB_AutoMoWah_2024-05-29.zip
Schematic_AutoMoWah_2024-05-29.pdf
