XL-10AH
PROXL-10AH
Reproduction cost: $5.5
Creation time:2025-12-25 11:42:12Update time:2025-12-26 07:15:41
Overview
The XL-10AH is a high-current DC power control module designed to function as an electronic switch or a power distribution interface. It is capable of handling significant current loads (up to 10A in well-ventilated conditions), making it a reliable alternative to mechanical relays for high-speed switching and long-term durability.
Key Features
  • High Current Capacity: Designed to support continuous loads up to 10A, suitable for demanding applications like heating elements or high-power LED arrays.
  • Wide Voltage Range: Compatible with a broad range of DC input voltages, typically used in $12V$ or $24V$ systems.
  • Solid-State Reliability: Unlike mechanical relays, this module offers silent operation, faster switching speeds, and a longer lifespan with no contact wear.
  • Low Heat Dissipation: Optimized PCB layout and low $R_{DS(on)}$ components ensure efficient power delivery with minimal energy loss.
Applications
  • DC motor control and high-power actuators
  • Automotive lighting systems and auxiliary power management
  • Industrial automation and DIY power distribution boards
  • High-power LED strip controllers
