INA219 Module
PROINA219 Module
Reproduction cost: $4.5
Creation time:2025-12-24 07:41:33Update time:2025-12-25 02:36:08
Overview
The INA219 is a digital current sensor breakout board that measures both high-side voltage and DC current draw over I2C. It is widely popular in the maker community for monitoring power usage in battery-powered projects and solar energy systems with an accuracy of approximately 1%.
Key Features
  • Simplified Power Monitoring: Measures bus voltages from $0V$ to $26V$ and handles up to $\pm 3.2A$ with the standard $0.1\Omega$ shunt resistor.
  • I2C Interface: Communicates easily with Arduino, Raspberry Pi, and ESP32. It supports up to 4 programmable addresses by bridging the address pins.
  • Calculated Data: Beyond raw voltage, the INA219 can internally calculate current and power ($P = V \times I$), reducing the processing load on your MCU.
  • High-Side Sensing: Unlike many cheap current sensors, the INA219 senses on the "high side" (between the power supply and the load), which doesn't disturb the ground path.
Applications
  • Solar panel output monitoring
  • Battery life estimation and testing
  • Over-current protection in DIY electronics
  • Real-time power logging for IoT devices
