CompletedSC734 v1.0 Micro SD module for RCBus-80pin
STDSC734 v1.0 Micro SD module for RCBus-80pin
18
Reproduction cost: $0
Creation time:2025-08-01 21:41:09Update time:2025-11-13 00:58:57
SC732 v1.0 Dual servo controller module for RCBus
Documentation at smallcomputercentral.com
This module provides simple bit-bang data transfer so it is slow, similar to a 1980 floppy disk but with much greater capacity.
The RCBus I/O port address for this module is set in binary with JP1. Fit a jumper shunt to each bit position where the address bit should be a logic ‘1’ (high voltage).
The address assumed by RomWBW is hexadecimal 69 or binary 01101001. The jumper shunt positions required for this address are illustrated below.
CloneAdd to Album
