Development Board - Arduino Uno with USB-C
STDDevelopment Board - Arduino Uno with USB-C
1.0k
Creation time:2024-07-08 01:09:49Update time:2025-09-28 11:03:02
ATmega328P development board based on the Arduino Uno with the same dimensions. It incorporates a USB-C for transmitting and receiving data, with double male and female headers for begginers, and a physical usb to external power supply (physical switch instead of the MOSFET and OPAMP switching).
It is recommended that the ATmega328P can be burned with the Arduino bootloader externally, or you could use the ISCP headers (check datasheet). All the smd are 0603, and the led colors are personalized. Also, the silkcreen could be changed for personal preference.
Finally, it uses the CH340C, so an external driver should be downloaded for its use (check device manager in windows). The CH340 driver is available in the internet, probably already installed if you have used an Arduino knockoff. With that, you can program it in the Arduino IDE or by using standard AVRDUDE.
Programming_Arduino_IDE.mp4
