Mini Router
PROMini Router
Creation time:2025-05-06 08:39:57Update time:2025-05-07 01:38:47
A mini router made using a router module with a processor of MT7628 (Ebaite E103-W20, compatible with HLK7628N).
As small as possible, using TPS54302DDCR for 3.3v power supply, resistor and capacitor 0603 package, leading out a network port (switching LAN/WAN function through switch), a 1.0mm * 4p terminal LAN port, USB2.0 interface, TF card interface, TTL serial port, antenna for ipex 1 generation
Chip solution: MT7628AN, operating frequency: 2.4GHz, transmit power: 20~ 24dBm, MCU frequency: 580MHz, communication distance: 200m, wifi protocol: IEEE802.11b/g/n.
Module Introduction: This module introduces all the interfaces of MT7628AN, supports OpenWrt operating system and custom development, has rich interfaces and powerful processors, can be widely used in smart devices or Cloud as a Service applications, and can be freely developed.
Ebaite Module Data: E103-W20
[Taobao] https://m.tb.cn/h.5izwevn?tk=tn0fWX9vgc1 CZ0001 "Ebyte serial port to WiFi patch low-power wireless routing module supports AP/STA"
Click the link to open it directly, or search Taobao to open it directly.
001
HLINK Module Data: HLK7628N
Breed firmware: breed-mt7688-reset38
OpenWrt firmware: Password: 58pp
Using lede branch, background IP: 192.168.8.1, password: 5845201314, compile parameters are as follows:
lede
Known issue: Due to the IO of the TF card and some network ports to be reused, after flashing the TF firmware, the network port will become unusable, and the technical problem cannot be solved temporarily. As the chip is too old and the performance is not good, it can only be played with reluctantly. Here are some test pictures.
哔哩哔哩YouTube
111
openwrt下载
Designed by Toolchen (from OSHWHub)
Link:https://oshwhub.com/toolchen/mini-router
breed-mt7688-reset38.bin
101
BOM_ mini_mini_open-source _mini_2023-11-04.xlsx
109
3DShell_mini_wifi_3D.zip
103
