Arduino Nano MIDI Controller
STDArduino Nano MIDI Controller
Creation time:2025-01-11 12:58:06Update time:2025-02-06 09:54:09
Input voltage: +12A / 1.0A
Onboard fuse rating: 1.5A (Can be changed per use case)
On board voltage regulator: L7809CV
MIDI Connector: DIN-5
Number of programmable buttons: 10pcs
Number of programmable potentiometers: 6pcs
A small prototyping area added if modifications are needed: 9 x 6 pads
More information can be found from:
https://www.youtube.com/@NotesAndVolts
Tested 14th Feb 2025: Found out that potentiometers needs to be pulled to 3V3. Revision 2.0 is created and published.
