ESP32-C6-WROOM-1-N8
PROESP32-C6-WROOM-1-N8
Mode:OSHWLab Stars
OSHWLab Stars
Reproduction cost: $15
CC BY-NC-SA 4.0
Creation time:2025-11-29 15:47:09Update time:2025-12-01 08:51:41
This project is a compact, cost-optimized development board built around the ESP32-C6-WROOM-1 module, designed for Wi-Fi 6 and Bluetooth LE applications. Inspired by the excellent work of YourSelft487, this version focuses on accessibility and manufacturability by switching to a two-layer PCB, significantly reducing fabrication costs.
A WS2812B-2020 RGB LED is integrated directly on the board and connected to IO18, making the module instantly ready for visual feedback, status indication, or addressable-LED experimentation without requiring any external components.
Also made some correction on the LDO routing. The original board had a small routing error.
⚠️IMPORTANT :
Please be advised, in order to be able to route all the nets on two layers I deleted the JTAG and SDIO pads from the footprint. These interfaces are not essential for the typical use cases targeted by this development board and eliminating them allowed me an easier routing :). If you specifically need those pins you will have to route them by yourself.
Have fun !
