[Verified]smartknob-original
PRO[Verified]smartknob-original
Creation time:2024-12-06 02:56:28Update time:2024-12-06 03:12:21
Verified (official version 0.4)
Project Source: https://github.com/scottbez1/smartknob
The purpose is to make it easier for everyone to use this version directly under the JLC PCB.
1 History
November 23, 2022: Update the tolerance list (using the components of the LCSC) and upload the modified shell information.
October 15, 2022: Hardware data view_base_1 of the EDA version of Richtron has been verified to be available, upload the official original firmware smartknob-releases-view_base-v0.4.
October 1, 2022: Upload official original hardware data (KICAD)
2 Structure
There is no way to buy the original motor, and it is difficult to reproduce 100% of the original version.
2.1 Motors
The micro gimbal motor I use Model 3205 three-phase brushless motor (there are two types) with NdFeB strong magnetic ring-Taobao (taobao.com).
2.2 Motor Adapter
After replacing the motor, the previous housing will be 1mm smaller and needs to be adjusted, please refer to the accessory CASING-V0.02.123DX.
The new motor does not match the bottom circuit board and needs to be adapted with a structural part, please refer to the attachment adapter-0808. STL (this file is from the QQ group 23691677)
2.3 Copper Pillars
For threading and fixing the screen in the middle, model M2.5*25, I use M2M2.5 double-pass hexagonal copper pillar M3M4 double-ended isolation column nut column support column motherboard computer stud M5M6-tmall.com Tmall
3 Hardware
  • L1 is not welded and replaced with 0R.
  • All the seats were not purchased, and they went directly to the wire.
  • Prepare a little ultra-fine multi-strand enameled wire to connect the motherboard to the screen.
4 Firmware
Designed by crazyd (from OSHWHub)
Link:https://oshwhub.com/13724384373/smartknob-original
view_base.zip
272
view_screen.zip
206
smartknob-releases-view_base-v0.4.zip
1101
adapter-0808.STL
191
casing-V0.02.123dx
171
