TOF Laser Distance Measuring Instrument
PROTOF Laser Distance Measuring Instrument
CERN Open Hardware License
Creation time:2024-09-25 08:02:16Update time:2024-09-25 10:11:22
1. Project Brief Introduction
The rangefinder developed based on the mall C190004 VL53L1 laser distance sensor, including: MCU driver circuit, lighting circuit, display driver, buzzer and other driving circuits and software.
2.Application scenarios
  • Dimensional measurement, position tracking, testing purposes.
  • Depending on this circuit or the associated peripheral drive, a wide range of applications can be expanded.
3.Hardware Parameters
  • Processor: ESP32C3 (WIFI, Bluetooth)
  • Screen: 0.96 TFT color screen
  • Operation: Multi-directional reset button
  • Power supply: Charging and discharging includes: lighting (flashlight), soft power on/off
  • Circuit: Buzzer, voltage sampling
4.Directions for use
Burning program, power on, save the settings with power-off, and automatically load the last setting.
When the main control chip is QFN package and soldering, please use the heating table → DC low-voltage heating table
Pay attention to distinguish between components with positive and negative electrodes to avoid short circuits.
 Please do not check whether there is a short circuit before powering on to avoid chip burning!!
Key function (illustrated below)
5.Program-related
1.Prepare the program to burn (TTL connection PCB RX TX GND)
2.Press and hold the middle button to insert the USB port, select the serial port, and click Start (wait for the program to be burned)
6.Test video
Designed by Origin_ (from OSHWHub)
Link:https://oshwhub.com/18511895537/TOFji-guang-ce-ju-yi
The rangefinder (test firmware).bin
281
The rangefinder.mp4
737
