[ LC panel printing ] Engraving card night light
PRO[ LC panel printing ] Engraving card night light
Creation time:2024-11-27 07:16:21Update time:2024-11-29 03:03:02
Master: ESP8266
Lamp beads: 5050 WS2812B
Firmware: WLED (https://kno.wled.ge)
M4*8 screw: https://detail.tmall.com/item.htm?id=627529370794 (specification selection M4*8)
Touch switch: https://item.taobao.com/item.htm?id=666739298345
Panel Printing Instructions:
The attached AI source file contains two copies of Nahida and one Klee.
When printing the panel, please use the attached "Klee-Nahida.ai" file.
Panel printing address: https://dos.szlcsc.com/dos/panel/print.html?f=top
Be sure to note that engraving is required!!
3D Printing Instructions:
3Dmonkey: https://www.sanweihou.com/
Select 3D printing, then extract the shell model file in the attachment, then upload the two STL files inside, and click Batch Edit.
Select Resin-X Resin.
PCB Soldering Instructions:
When welding, the red wire is welded to the red arrow, the yellow wire is welded to the yellow arrow, and the black wire is welded to the black arrow.
Firmware Flashing Instructions:
Use TTL to connect the board
TTL RXD connects the board TXD
TTL TXD connects to the board RXD
TTL 3.3 connects to board 3.3
TTL GND connects to board GND
Chinese firmware please refer to: https://www.bilibili.com/video/BV1t14y1h7f1/
The Android version of the app is available as an add-on, or you can download it from the Google Play Store.
If conditions permit, you can go directly to the online burning address of the official website for online burning.
Address: https://install.wled.me/
If you don't have any conditions, you can download the firmware file in the attachment and unzip it, and open the ESP8266Flasher.exe inside
Choose your serial port.
Click on the Config tab, then click on the pinion icon in the first row to select the WLED_0.13.3_ESP8266.bin in the firmware folder
Select the Advanced column and Baudrate select 115200.
Go back to the Operation tab and click on the Flash button.
At this time, press and hold the FLASH button on the board, and then press the RST button again to enter the download mode.
Wait for the progress bar to finish, and press the RST button on the board when you are done, and the light should be on at this point.
Take out your mobile phone, turn on the wifi, and connect to a wifi called WLED-AP, the password is wled1234.
Once connected, a web page should automatically open for wifi configuration.
Select WIFI SETTINGS for WiFi configuration.
If you don't want to set up wifi, you can directly click TO THE CONTROLS below.
Enter your home's wifi name and password, then click Save & Connect on the right side to save the configuration.
At this time, you can see the IP address of the WLED from the router management interface, and the browser enters the address.
Click Config.
Click on LED Preferences
Change the number of lamps to 12 and click Save at the bottom to save the configuration.
After the APP is opened, click + in the upper right corner to add a device.
You can automatically search for the device, if you can't find it automatically, please add it manually, enter the IP address of the device and click the √ in the upper right corner.
Installation:
Use screws to fix the PCB on the shell, and then install the bottom cover, it should be noted that the screw holes must be completely aligned to be correct.
Designed by 小渣渣 (from OSHWHub)
Link:https://oshwhub.com/myzhazha/li-pai
Klee-Nahida.ai
481
The base model .zip
307
WLED_1.0.3.apk
438
video.mp4
469
Firmware .zip
371
