Iot-type Multi-protocol Power Supply
PROIot-type Multi-protocol Power Supply
1.3k
CERN Open Hardware License
Creation time:2024-10-08 09:11:14Update time:2024-10-11 03:19:59
This project is completely designed using JLC's EDA. If you like this project, please give it a like in the comment area. Thank you for your support!
Everyone is welcome to collect this project.
Based on ESP_PICO, the control unit is equipped with SW3526 multi-protocol fast charging source with redundant power of 231W.
Communication group: 754881030
The basic functions have been completed and the program source files have been uploaded. The capabilities are generally limited and may not be perfect in some places. Please don’t complain. Children who have other ideas can freely express themselves based on this.
Update log: March 1, 2024
1. Arrangement of relevant documents
2.Adjusted some parameters
Update log: 1.1 on January 15, 2024
1. UI redraw, C port/A port button switch
2. Output control, add WEB control, scan
3. Parameter adjustment Page
  • Add C/A port switch status
  • Buzzer switch
  • Single port voltage display
  • Overpressure alarm (don’t know what it’s used for)
  • Screen brightness adjustment
  • Save after power off
4. WIFI network configuration, scan access control
PCB Simulation Diagram
⚫ Press the encoder without letting go → The programmer is powered on TTL (if the welding buzzer will sound for a long time)
Select the corresponding serial port and click Start to wait for the program to be burned. Just cut off the power and restart (provided there is no problem with welding!)
Key Operation
Design Considerations
The PCB is a double-layer stacked structure. Pay attention to the installation skills, which are included in the panel and other projects.
Shell Taobao 8 piece aluminum alloy shell 60*38*88.
Test Video
Designed by Origin_ (from OSHWHub)
Link:https://oshwhub.com/18511895537/dian-zi-luo-pan-di-ci-yi
Power supply firmware V1.0b.0b
438
Burning program flash_download_tool_3.9.4_0.9
1256
Test video.mp4
608
SmartCharge1.1.bin
235
Network distribution instructions.docx
246
Iot Multi-Protocol Power Supply (source code).rar
1544
