CompletedUniversal ESP32C3 controller replaces WL infrared version
280
:CC BY-NC-SA 4.0
Creation time:2024-12-06 03:38:58Update time:2024-12-06 03:40:56
Modeled on the platform of the wind espmini remote control to do a version of the universal esp32C3 version, through the experiment can be used for the main control board of WALL-E robot, on the targeted a little modification.
Using the espNOW protocol, point-to-point one-to-one is written in the program, and the program can be changed to WiFi remote control mode (LAN or WAN) by modifying the program.
It's much more stable than the Bluetooth version of the mobile phone I did before, the Bluetooth version has higher requirements for the mobile phone, and it's irregular, some mobile phones will release the button when the remote control trolley doesn't stop, and the Bluetooth module will often be disconnected.
Although the handle uses a joystick, it can only be used as a button, because instead of the 6-button infrared remote control, there are only buttons on it. If you have time later, or who is interested, you can replace the joystick with a button so that there will be no misunderstanding.
This project is that the sender also needs to be used with the receiver. You can use the same C3, esp8266 and other modules or development boards that support espNOW.
Programming uses the latest version of Mixly 2.0.
Designed by 得劲滋润爽 (from OSHWHub)
Link:https://oshwhub.com/djzrs/he-zhou-esp32c3-shou-bing-ti-dai-wl-hong-wai-ban
The preview image was not generated, please save it again in the editor.Add to Album
