Fujitsu F-07C Docking Station V3.0 with Built-in HUB Version
PROFujitsu F-07C Docking Station V3.0 with Built-in HUB Version
CC BY-NC-SA 4.0
Creation time:2025-07-31 02:54:30Update time:2025-07-31 06:00:09
Previous version without built-in HUB:
https://oshwhub.com/wn3dl/fujitsu-f-07c-docking-station
(This is the first PCB I've drawn as a newbie, so go easy on me 😂. Feel free to point out any suggestions or issues!)
F-07C is a mobile phone/UMPC launched by Fujitsu in the Japanese domestic market in 2011, running the Symbian + Windows 7 system.
The original docking station/base is not included with the device but needs to be purchased separately, so many users only have the standalone device. However, some experts on the internet have shared the pinout definition of the F-07C 30P interface, making it possible to create homemade adapters. However, all homemade adapters only have USB female ports, and it seems that no one has attempted to create an HDMI output. The HDMI and USB ports of the original docking station are not directly connected to the 30P pins of the phone but are routed through two chips: the BU16025 Buffer IC and the SMSC USB2514B USB HUB IC. Testing has shown that a USB mouse cannot be used without connecting the USB HUB, and HDMI can still output normally, although there are occasional minor instability issues (such as occasional minor tearing/flickering) (the new version with a built-in HUB has redesigned the HDMI circuit, significantly reducing interference. I also obtained the original docking station and found that even when playing Minesweeper, there is still occasional minor tearing 😂) , and future versions plan to include a USB HUB chip, eliminating the need for an external HUB .
For the other 30P male connectors, I used Apple connectors and cut one side for use. The original connectors are also available for sale but are extremely expensive; they are JAE's DD1 series connectors.
What changes are there compared to the previous version?
In addition to adding the SL2.1A USB HUB chip, the HDMI circuit has been redrawn, routed through the middle of the 30P interface, and pins 1, 8, and 30 of the 30P interface have been removed to facilitate better routing.
Where did you buy all your components?
Except for the 30P male connector, HUB chip, and capacitor crystal oscillator, I purchased all components from "Shenzhen Ruibochang Technology Co., Ltd." on 1688 and you can search for them on your own. The 30P male connector was purchased from "Imported Shock Absorber Mesh Collection" on Xianyu.
(Not an advertisement, didn't receive a single cent)
Are there any finished products available for purchase?
Yes! You can find me by searching for my username WN3DL or the keyword F-07C on Xianyu. Additionally, I also make adapters for sale.
PS: Don't use this for profit~
The two on the left are the first-made ones for functional testing, the two black ones in the middle are the made adapters, and the two on the right are the finished-made docking stations.
30P Pin Definitions:
01 OUT Winモード動作中は3.3V、スリープ中は0.75V *1
02-04 IN 5V (本体への5V電源供給用) *2
05-07 IN 5V (本体への5V電源供給用) *2
08 IN クレードルで19V->5V変換中は3.5V *3
09 GND
10 IO USB DATA- (SMSC USB2514BのD-(30)へ)
11 IO USB DATA+ (SMSC USB2514BのD+(31)へ)
12 GND
13 OUT HDMI用スイッチっぽい
14 GND
15 IO HDMI SDA (BU16025を介してHDMIコネクタへ)
16 IO HDMI SCL (BU16025を介してHDMIコネクタへ)
17 GND
18 OUT HDMI CLK- (BU16025を介してHDMIコネクタへ)
19 OUT HDMI CLK+ (BU16025を介してHDMIコネクタへ)
20 GND
21 OUT HDMI D0- (BU16025を介してHDMIコネクタへ)
22 OUT HDMI D0+ (BU16025を介してHDMIコネクタへ)
23 GND
24 OUT HDMI D1- (BU16025を介してHDMIコネクタへ)
25 OUT HDMI D1+ (BU16025を介してHDMIコネクタへ)
26 GND
27 OUT HDMI D2- (BU16025を介してHDMIコネクタへ)
28 OUT HDMI D2+ (BU16025を介してHDMIコネクタへ)
29 GND
30 IN 19V電源接続中は3.5V *4
*1 本体が接続されていないと、クレードル側の19V->5V変換が動かない。
*2 両方の5V供給が無いと充電中にならない
*3 この信号で充電可否を判断している (未接続では浮いてるっぽい)
*4 この信号で電源管理がAC接続を判断している (未接続では浮いてるっぽい)
Please do not refer to the following BOM table! It is completely incorrect!
