CompletedDP to HDMI video output module
255
Creation time:2024-12-24 03:13:24Update time:2024-12-24 07:16:59
PS176-based DP to HDMI
1 DP to HDMI
The project itself serves as a foresight for subsequent projects, and as a technical PCB to accumulate and implement the technology stack.
The PCB can realize the conversion of DP signal and HDMI signal, support 4K@60 (display 1080P@144hz, still pass the test, test time: two and a half hours)
2 Project Progress
【2023.01.11】
- [V1 Version]
- The 20-pin of the DP does not generate a power input when it is used as a sink terminal, so a 3.3 power supply from an external flying cable is required. (See post-test chart)
- PCB with a male port in the project needs to be able to sample and test by yourself (I will also test it in the future)
3 Atlas
Designed by lemon_wifi (from OSHWHub)
The preview image was not generated, please save it again in the editor.Add to Album
