1000W High power 220V input adjustable power supply (0-100V output)
PRO1000W High power 220V input adjustable power supply (0-100V output)
CC BY 3.0
Creation time:2025-03-04 06:06:24Update time:2025-03-04 09:15:48
1. Parameters and specifications
Rated input voltage: 220VAC 50Hz or 280V~380VDC (within +-10% of rated voltage)
Output voltage: 0-100VDC continuously adjustable
Output current: 0-10A continuously adjustable
Rated output power: 1000W
Efficiency: ≥90%
Regions of use: China
Ambient temperature: -20°C~55°C, humidity: 0%~70% (no condensation)
Altitude conditions: 0~2KM
Protection function: OVP, OCP, OTP
Mr. Lei talked about the comprehensive upgrade of electronics: the project update time is once every 4 months, and each time the project is fully stressed tested, thermal test, derating test and other reliability tests, and all components can be purchased on Taobao to ensure that everyone can reproduce and operate stably and reliably.
Bilibili search Mr. Lei said that the complete calculation data can be downloaded electronically, and this project can be contacted by commercial authorization.
2. Principle introduction
Physical display
Component procurement and transformer design
Name Quantity
Auxiliary power supply 12V 1A 1
Voltmeter, ammeter 1
Isolated drive TR1375 20:40 1
PQ5050 transformer 1
0.1*250/litz line 5m 1
The output inductance is 330uH 20A 1
potentiometer 2
4*4cm violent fan 1A or less 1
F6 radiator + screws, insulating sheet, thermally conductive ceramic 1+4
Physical display
Precautions
This project involves high voltage, safety first, do not touch the capacitor with your hands.
When the output of 1000W power requires a fan to strengthen heat dissipation, it must be ensured that the heat dissipation is good before it can run at full power to prevent overheating.
The debugging process must be understood on Bilibili before powering on. There is a full set of tutorials in Bilibililei to teach electronics.
Demo video: The full set of tutorials is here
Designed by 雷老师讲电子 (from OSHWHub)
Link:https://oshwhub.com/leichaolin/1kw-adjustable-power-supply
96ac03bda7e423267618d735b2cf2237.mp4
171
