PCBMOTOR DRIVER BTN9990LV 75 AMPERE MAX, THE GREATEST MOTOR DRIVER EVERRR!!!!
2026-01-04 07:00:33
Dual DC Motor Driver Using BTN9990LV
Full-Bridge Bidirectional Control and Performance Optimization
1. Overview of BTN9990LV
The BTN9990LV is a high-current half-bridge motor driver IC from Infineon based on Smart Power Technology. It is designed for reliable DC motor control in automotive and industrial applications.
Key Features:
  • Type: Half-Bridge Motor Driver
  • Operating voltage: 5.5 V – 40 V
  • High output current capability (up to ±75 A peak)
  • Integrated protections:
    • Overcurrent protection
    • Overtemperature protection
    • Undervoltage lockout
    • Short-circuit protection
  • Supports high-frequency PWM
  • Logic-level compatible (3.3 V and 5 V microcontrollers)
2. Full-Bridge Configuration Using BTN9990LV
Since BTN9990LV is a half-bridge device, a full-bridge (H-bridge) requires two BTN9990LV ICs per motor.
IC Requirement:
  • 1 bidirectional DC motor → 2 × BTN9990LV
  • 2 bidirectional DC motors4 × BTN9990LV
This configuration allows complete control of motor direction, speed, and braking.
3. Operating Principle of Bidirectional Full-Bridge
A full-bridge enables:
  • Forward rotation
  • Reverse rotation
  • Dynamic braking
  • Free-running (coast)
Control Logic Example:
IN_A IN_B Motor State
PWM LOW Forward
LOW PWM Reverse
HIGH HIGH Brake
LOW LOW Free running
PWM signals are used for speed control, while logic levels define rotation direction.
4. Basic BTN9990LV Circuit Description
Important Pins:
  • IN – Logic/PWM input
  • EN – Enable pin
  • OUT – Motor output
  • VS – Motor supply voltage
  • GND – Ground
  • IS – Current sense output
  • SR – Slew rate control
Typical Connections:
  • VS → Motor power supply (e.g., 12 V or 24 V)
  • GND → System ground
  • IN → Microcontroller GPIO/PWM
  • EN → Logic HIGH to enable
  • OUT → Motor terminal
5. Dual Motor Control Architecture
For two motors:
  • Motor 1 → BTN9990LV (A & B)
  • Motor 2 → BTN9990LV (C & D)
Each motor has independent PWM and direction control, enabling differential drive or independent speed regulation.
6. Performance Optimization Techniques
6.1 Power Supply Design
  • Place bulk capacitors (470 µF – 1000 µF) close to the VS pin
  • Add 100 nF ceramic decoupling capacitors
  • Use short, wide PCB traces for power paths
✔ Reduces voltage drop and electrical noise
6.2 PWM Configuration
  • Recommended PWM frequency: 15 – 25 kHz
    • Above audible range
    • Improved efficiency
  • Always use hardware PWM for stable control
6.3 Slew Rate Control (SR Pin)
  • Use an external resistor on the SR pin
  • Slower slew rate:
    • Lower EMI
    • Reduced thermal stress
  • Faster slew rate:
    • Faster motor response
✔ Select based on application requirements
6.4 Current Sensing (IS Pin)
  • Use the IS pin to:
    • Monitor motor current
    • Detect motor stall or overload
    • Implement software-based protection
  • Apply ADC filtering for stable measurements
6.5 Thermal Management
  • Use large copper areas on the PCB
  • Add thermal vias under the IC
  • Attach a heatsink for continuous high-current operation (>5 A)
6.6 Additional Protection
Although BTN9990LV has internal protection:
  • Add TVS diodes on the motor supply
  • Use fuses or polyfuses
  • Implement star-grounding topology
7. Advantages of BTN9990LV Compared to Conventional Drivers
Feature BTN9990LV L298
Efficiency High Low
Current capability High Low
Protection Comprehensive Minimal
Voltage drop Very low High
High-frequency PWM Yes No
8. Typical Applications
  • Differential drive robots
  • Automated Guided Vehicles (AGV)
  • Line follower robots
  • Industrial DC motor control
  • Smart actuators
9. Conclusion
A motor driver based on BTN9990LV is a robust and efficient solution for dual DC motor full-bridge bidirectional control. With proper power supply design, PWM configuration, and thermal management, the system achieves:
  • High efficiency
  • Stable operation
  • Reliable protection
  • Precise motor control
This makes BTN9990LV ideal for high-performance robotic and industrial motor applications.
Link:
https://drive.google.com/drive/folders/1PoshLd9N2BOwwoIAyyH2I7-uXxUVBLAV?usp=sharing
Writer:
Bintang Adhiyaksa Dani Saputro
+62822-2306-9220
bintangadhiyaksa@gmail.com
