OthersIf your Mac OS can't install EasyEDA client
2025-06-11 01:48:05
If EasyEDA Pro cannot run on your Mac
Try the following steps in turn, if it still doesn't work, go to the next step.
1.
After decompression, open the terminal in this directory and run this command:
xattr -r -d com.apple.quarantine "EasyEDA-Pro.app"
Close the terminal and try to double-click the app to run it.
2.
In "System Settings - Privacy & Security - General - Allow applications downloaded from" select "Open anyway" to allow the system to allow the application to run.
3.
Hold down the Control key and click the APP, and select Open in the pop-up shortcut menu.
4.
Go to the forum post to check other solutions, if you still can't solve it, you can contact the manual customer service.
references:
