ELRS PWM 2.4Ghz
PROELRS PWM 2.4Ghz
OpenAtom OHL 1.0
Creation time:2026-06-02 05:45:04Update time:2026-06-03 02:27:13
ExpressLRS (ELRS) is an open-source radio control protocol known for its high performance, long range, and high refresh rate.
Project page:
https://github.com/ExpressLRS/ExpressLRS/
This ELRS receiver is a custom PWM-output version that supports 6 independent PWM output channels, making it ideal for fixed-wing aircraft, RC vehicles, boats, and other applications that do not require a flight controller. The receiver can also be flashed with standard ExpressLRS firmware to output the CRSF protocol for use with compatible flight controllers.
The receiver provides low-latency, long-range control while maintaining the flexibility of the ExpressLRS ecosystem. PWM channel mapping can be customized through the built-in Wi-Fi configuration interface, allowing users to assign receiver channels to any PWM output as needed.
By default, all six outputs operate as standard servo-compatible PWM signals, supporting a wide range of RC electronics including servos, ESCs, relays, and auxiliary devices.
