F5305S P-Ch MOSFET Module HW-548
PROF5305S P-Ch MOSFET Module HW-548
Creation time:2026-05-26 13:17:13Update time:2026-06-09 07:17:06
[WARNING] Fatal Design Flaw in the Cheap "HW-548" (F5305S) MOSFET Module
Overview
The HW-548 (often sold simply as the "F5305S module") is an ultra-affordable P-Channel MOSFET module widely available on platforms like Taobao, AliExpress, and Amazon for just a couple of bucks (around 2 RMB in China).
At first glance, it looks like an excellent solution for driving high-current loads (motors, LEDs) directly via a microcontroller's PWM signal. However, this module has a fatal circuit design flaw. If you apply 24V or 36V as advertised, the MOSFET will be destroyed instantly.
This article is based on reverse engineering the module to expose its critical defects and to warn the maker community about what is already known in several engineering forums: this module is a trap.
The Misleading "Official" Specifications
Here are the specifications typically claimed on the sellers' product pages:
Parameter Claimed Specification
Switching Component F5305S (P-Channel MOSFET)
Control Signal (Input) DC 3V – 20V (Logic-Level compatible)
Input Current Approx. 5mA
Load Voltage (Output) DC 5V – 36V ⚠️ (This is a blatant lie)
Rated Current (Output) 5A (Up to 20A with a proper heatsink)
Operating Temperature -40°C to 85°C
Advertised Features:
  • Logic-Level Input: 3V–20V trigger range, supposedly allowing direct MCU connection.
  • Smooth PWM Control: For stepless motor speed or LED brightness adjustment.
  • Signal and Load Separation: Designed to isolate the input circuit from the output circuit to protect the MCU.
The Fatal Design Flaw Revealed by Reverse Engineering
After tracing the PCB layout and reverse-engineering the schematic, an unbelievable design mistake was discovered: the voltage divider circuit does not function at all.
Normally, when switching high voltages with a P-Channel MOSFET, a proper voltage divider is required at the gate to ensure that the Gate-Source voltage ($V_{gs}$) never exceeds the absolute maximum rating (usually around ±20V).
However, the routing on the HW-548 PCB looks something like this:
  • Source $\rightarrow$ Resistor $\rightarrow$ Resistor $\rightarrow$ Gate
  • Source $\rightarrow$ Resistor $\rightarrow$ Switching Component $\rightarrow$ GND
Because of this incorrect topology, there is no actual voltage division happening. When the switch (trigger) is turned ON, the gate is pulled down almost directly to GND level.
Why It Fries at 24V
According to the F5305S datasheet, the absolute maximum rating for the Gate-to-Source voltage ($V_{gs}$) is ±20V.
Because of the flawed circuit design, the load voltage is applied almost entirely across the gate and source when triggered.
  • If you apply a 24V load, $V_{gs}$ becomes -24V.
  • If you apply the advertised max of 36V, $V_{gs}$ becomes -36V.
In both scenarios, the absolute maximum rating is severely exceeded. The gate oxide layer breaks down, and the MOSFET is instantly destroyed (shorted or blown open). Claiming a "Load Voltage: 5V – 36V" for this specific board design is physically impossible and completely false.
The Tricky "12V Trap"
The most frustrating part of this module is that it actually works fine if you only use it at 12V.
If your load voltage is 12V, $V_{gs}$ is pulled to -12V, which is well within the safe ±20V limit. Because of this, makers who use it for 12V LED strips or small motors leave positive reviews, tricking others into thinking it's a reliable product.
It is highly likely that the original designer prototyped the PCB, tested it only with a 12V power supply, concluded that "it works," and pushed it into mass production without realizing the fatal topological error.
A Known Issue in the Community
This issue is not entirely new; it has been discussed in various overseas electronics forums and maker communities. You will frequently find posts from confused users saying, "I connected my 24V motor and magic smoke came out," or "The specs are a lie." Hardware-savvy users have already pointed out the missing/flawed voltage divider.
Unfortunately, because it is so incredibly cheap to produce, it continues to flood the market as a "36V compatible" module, claiming new victims every day.
Conclusion and Recommendations
Do NOT use the HW-548 (F5305S) module in any system exceeding 15V (practically 12V), despite what the specifications say.
Your Options:
  1. Limit the Voltage: Use it strictly at your own risk for 12V systems or lower, where the $V_{gs}$ will not exceed the 20V threshold.
  2. Modify the Board: You can manually cut the PCB traces and solder in proper resistors to form a functional voltage divider. However, given the extreme cheapness of the module, the time and effort are rarely worth it.
  3. Buy a Better Module: If you need to switch 24V or 36V loads, look for properly designed MOSFET modules (or build your own circuit) that explicitly include a correctly implemented gate voltage divider or dedicated gate driver IC.
Don't let the low price fool you. Using this module as advertised is not only a waste of money but also a potential fire hazard.
Simulator
