devices or 10W pads
standardized processes
devices or 1000 pads
PRO To youth - Painted dream ESP32 learning board
Mode:
ESP32-WROOM-E
module as the main control, and supports WIFI, Bluetooth, Ethernet, RS485, CAN and other communication modes. Individuals are ready to learn IoT development with MicroPython
on the Thonny IDE
. It is different from the open source learning program of the source guy.
CH343P
auto-download circuit. The original CH340 usb to ttl circuit has been upgraded to make it smaller, faster and more stable.
ESP32-WROOM-32E, dual-core
240MHz, can be used for WIFI,
Bluetooth
, Ethernet
development and application.IO is fully ejected
for easy debugging and expansion.Expandable LAN8720
100 Gigabit Ethernet, which plugs into the upper right corner of the board for wired Ethernet expansion.ST7789V + FT6236U
, IPS full viewing angle, single point capacitive touch, feel and life are greatly better than resistive screens.18650
battery holder, lithium battery protection
and lithium battery charge and discharge management
. When the power switch is turned on, 3.3V is the uninterruptible power supply, and the ESP32 will not restart due to USB plugging and unplugging.CH343 automatic download
circuit, connect with the computer only need to use the TypeC cable, no additional downloader is required.Integrated six-axis IMU accelerometer gyroscope (ICM-20600), SHT30 temperature and humidity sensor, PCF8563 independent RTC, infrared transceiving/transmitting, light sensing and other sensors, one board to play with smart home.
At present, it has been verified that the serial port connection is normal, and the program download and burning are also quite stable. Simple IO port control applications are normal.
Lithium battery charging, battery-power automatic switching and other power supply circuits are tested stably.
Designed by zack99499 (from OSHWHub)
Link:https://oshwhub.com/zack99499/To-the-youth-dream-ESP32-learning-board
