PCBTop silkscreen layer barely visible (Problem) - EasyEDA Pro
2024-06-24 09:32:17
Hello,
I have a problem in EasyEDA Pro version. The TopSilkScreen layer is no longer visible (or better said Barely visible). This is very annoying because I don't know where exactly the components will be located. Its hard to further connect the lines or make jumpers...
This is how the problem I have looks - you can not see any component marking of TopSilkScreen
If I Zoom in I can barely see the TopSilkScreen component layout and index.
I have several versions of the same layout (because I am not happy with so far layout version)
And in some versions the SilkScreen is shown as it should be - clearly visible with all data!
This has happened to me twice so far. Because I could find the solution I deleted the whole version and started over (that fixed the barely visible issue). But now I don't want to delite it.
Does anyone else have this problem? Can anyone help me fix it?
Popular Posts
More
