PCBExporting DXF Files
2025-10-29 23:35:26
I have a very simple 2 layer board that I'm trying to export as DXF files so that a friend can set it up in his CAM software. The top layer exports mostly properly (Doesn't export the traces correctly but he's able to work around that). The problem is that I can't get the bottom layer to export correctly at all. If I export it with "Copper Region" selected, the ground pour doesn't show up. If I export it with "Copper Region (Filled)" selected, the ground pour covers the whole board (except pads and holes) and eliminates the traces. I have tried to copy and past this layer into a new PCB and even made it the top layer, but nothing I try gets it to export properly. Has anyone run into this before?
