Mini Digital Camera With ESP32-S3 Cam & ST7789 Display
PROMini Digital Camera With ESP32-S3 Cam & ST7789 Display
1.3k
Mode:OSHWLab Stars
OSHWLab Stars 2026
Reproduction cost: $25
CC BY 4.0
Creation time:2026-03-22 19:01:42Update time:2026-03-23 11:34:04
DIY Mini Digital Camera (XIAO ESP32-S3 Sense & ST7789)
Overview
This project utilizes the Seeed Studio XIAO ESP32-S3 Sense as the primary controller to capture real-time images through its integrated OV2640 camera sensor, streaming the video feed directly onto a 240x240 px ST7789 TFT LCD display.
The standout feature of this build is its Triple-Button Interface, which allows users to interact seamlessly with their media by toggling between live streaming, capturing high-resolution photos, and instantly reviewing them from the microSD card storage.
Step 1: PCB Design & Fabrication
To achieve such a compact form factor, I designed a custom PCB using EasyEDA. This ensures all components—from the XIAO module to the triple-button interface—fit perfectly into a handheld size.
Note on Fabrication: If you want to replicate this build with a professional finish, the design is fully compatible with JLCPCB’s manufacturing service. Ordering the boards through them is a great way to ensure the 0603 SMD pads are precise, making the soldering process much smoother and the final result more durable.
Step 2: Soldering & Hardware Modification
Assembly requires a bit of patience due to the SMD 0603 footprints.
  1. Small Parts First: Solder the resistors (R1-R3) and capacitor (C1).
  2. Switches & Transistor: Solder the S8050 transistor, power switch, and tactile buttons.
  3. Core Modules: Attach the ST7789 LCD and the XIAO module.
Critical Hardware Hack: To prevent communication conflicts between the LCD and the SD card:
Action: Locate the J3 pad on the XIAO expansion board. This step is essential for the SD card to initialize properly.
Step 3: Firmware & IDE Setup
Upload the code via Arduino IDE. You can find the library and its documentation on GitHub here: https://github.com/pajrigithub/ESP32-S3-Mini-Camera. Make sure to install it via the Library Manager or by downloading the ZIP from the link provided.
Optimized IDE Settings:
- Board: Seeed XIAO ESP32S3
- PSRAM: OPI PSRAM (Required for the camera buffer)
- Flash Mode: QIO 80MHz
Button Navigation:
- BTN_SHOOT: Capture Photo / Return to Live View.
- BTN_NEXT: Enter Gallery / Next Image.
- BTN_PREV: Previous Image.
Result :
Check Video for result
CAM-ESP32S3.ino
camera_pins.h
