Ongoing5V to 3.3V converter
PRO5V to 3.3V converter
:MIT License
Design Motivation & Ideas
This SMD Linear Voltage Regulator module was designed to provide a clean, ultra-compact, and reliable solution for stepping down DC voltage, deliberately avoiding the high-frequency switching noise characteristic of standard buck converters. An entirely Surface Mount Device (SMD) architecture was selected to minimize the physical footprint, allowing the board to function as a universal, drop-in power module for space-constrained projects. Furthermore, the layout serves as an excellent educational platform for practicing SMD component placement and reflow soldering techniques.
Project Overview
This project is a compact, highly stable SMD Linear Voltage Regulator Power Module. Designed entirely with Surface Mount Device (SMD) components to minimize physical footprint and reduce weight, it takes a raw DC input voltage and steps it down to a clean, regulated DC output. It is an ideal sub-circuit for providing smooth, reliable power to space-constrained systems like rover telemetry arrays, communication modules, or custom sensor PCBs.
Technical Specifications & Circuit Architecture
1. Core Regulation
Surface-Mount Regulator (U1): The board is designed around a standard SMD 3-pin linear voltage regulator (such as the AMS1117 in a low-profile SOT-223 package).
Input/Output Interface: Features standard 2-pin headers (
H1for input,H2for output) allowing for easy wire-to-board connections or direct integration as a daughterboard on a larger main system.
2. Dual-Stage SMD Power Filtering
To ensure a completely stable power rail and prevent voltage droop, the circuit utilizes a low-profile SMD passive filtering stage on both ends:
Input Decoupling: Uses a 10uF SMD bulk capacitor (
C2) alongside a 0.1uF SMD ceramic bypass capacitor (C4) to smooth the incoming raw DC supply. -
Output Decoupling: Mirrors the input stage with a 10uF capacitor (
C1) for rapid transient load response and a 0.1uF capacitor (C3) to filter high-frequency noise from reaching downstream digital components.
3. Status Indication
Visual Feedback: Includes an integrated power-status circuit featuring an SMD indicator LED (
LED1) and a 10K surface-mount current-limiting resistor (R1). This provides immediate visual confirmation that the power rail is active and stable without taking up excess board space.
