STD STC8H1K08 36I Development Board
License: CC BY-SA 3.0
  • 519
  • 0
  • 0
Update time: 2023-12-22 11:39:03
Creation time: 2023-10-11 17:49:30
# STC8H1K08-36I-TSSOP20 Development Board Development board for the STC8H1K08 ultra-cheap 8-bit 8051 core microcontroller with integrated USB-to-serial adapter which can also be used to upload firmware utilizing the factory built-in serial bootloader. - Project Files (Github): https://github.com/wagiminator/Development-Boards/tree/main/STC8H1K08_DevBoard ![STC8H1K08_DevBoard_pic1.jpg](https://raw.githubusercontent.com/wagiminator/Development-Boards/main/STC8H1K08_DevBoard/documentation/STC8H1K08_DevBoard_pic1.jpg) # Pinout ![STC8H1K08_DevBoard_pinout.png](https://raw.githubusercontent.com/wagiminator/Development-Boards/main/STC8H1K08_DevBoard/documentation/STC8H1K08_DevBoard_pinout.png) # The STC8H1K08 Family of 8-bit 8051 Microcontrollers ## Overview The STC8H1K08 series is a cost-effective family of 8-bit microcontrollers with an ultra-high speed 8051 core that is compatible with the MCS51 instruction set. These microcontrollers offer an average instruction speed that is approximately 12 times faster than the traditional 8051, with most instructions requiring only one clock cycle for execution. They support clock frequencies of up to 36MHz, operate within a voltage range of 1.9V to 5.5V, and come equipped with standard peripherals such as a 10-bit ADC, analog comparator, multiple timers, PWM, UART, SPI, and I2C. Additionally, these microcontrollers feature a built-in bootloader, allowing firmware to be uploaded directly via UART without the need for an extra programming device. ## Features - Ultra-high-speed 8051 core with single clock per machine cycle (1T) - Fully compatible instruction set with the traditional 8051 - Maximum 36MHz system main frequency - Up to 17KB of Flash for user code (CODE) - 128 bytes internal direct access SRAM (DATA) - 128 bytes internal indirect access SRAM (IDATA) - 1024 bytes internal extended SRAM (XDATA) - 4KB EEPROM, can be erased more than 100,000 times - Operating voltage: 1.9V - 5.5V - Internal high-precision RC clock (IRC), adjustable to a max of 36MHz, error ±0.3% - Internal 32KHz low-speed oscillator (LSI) with a large error - External 4MHz - 33MHz oscillator or external clock (HSE) - Power-on reset, programmable low-voltage detector - 17 interrupt sources and 4 interrupt priority levels - Multiple low-power modes: Idle, Stop - Up to 17 GPIOs (P1.0 - P1.7, P3.0 - P3.7, P5.4) - 4 modes for all GPIOs: quasi-bidirectional, push-pull output, open-drain, high-impedance input - 8 channels enhanced 16-bit PWM, complementary output with dead time, external pulse width measurement - 3x 16-bit timers with multiple operating modes - 1x watchdog timer - 2x UART interface, max baud rate F_CPU/4 - 1x SPI interface, master and slave mode - 1x I2C interface, master and slave mode - 1x 10-bit ADC, 9 channels + internal 1.19V reference voltage, 500ksps - 1x set of comparators - Factory-built-in UART bootloader # Compiling, Programming and Debugging ## SDCC Toolchain For compiling install the SDCC compiler. On Linux (Debian-based), this can be done with the following command: ``` sudo apt install build-essential sdcc ``` ## Factory built-in UART Bootlader The MCU has an embedded bootloader with UART interface, which can be used to upload firmware using the CH340E USB-to-serial adapter integrated into the board. The Python tool [stc8isp.py](https://github.com/wagiminator/MCU-Flash-Tools) included with the example software can be used for this purpose. In order for this ISP tool to work, Python3 must be installed on your system. To do this, follow these [instructions](https://www.pythontutorial.net/getting-started/install-python/). In addition [PySerial](https://github.com/pyserial/pyserial) must be installed. On Linux (Debian-based), all of this can be done with the following commands: ``` sudo apt install python3 python3-pip python3 -m pip install pyserial ``` You can also utilize the manufacturer's proprietary programming tool, [STC ISP](https://www.stcmicro.com/rjxz.html), for programming the MCU. To upload firmware through the USB port, press and release the DOWNLOAD button when prompted by the ISP software to perform a power cycle. This button interrupts the power supply to the MCU, forcing it to enter bootloader mode. ## Arduino IDE Support An Arduino core for the STC8H series can be found [here](https://github.com/ma6254/Arduino_Core_STC). # References, Links and Notes - [EasyEDA Design Files](https://oshwlab.com/wagiminator) - [STC Product Page](https://stcmicro.com/stc/stc8h1k08.html) - [STC ISP Software](https://www.stcmicro.com/rjxz.html) - [MCU Templates](https://github.com/wagiminator/MCU-Templates) - [MCU Flash Tools](https://github.com/wagiminator/MCU-Flash-Tools) - [Arduino Support](https://github.com/ma6254/Arduino_Core_STC) ![STC8H1K08_DevBoard_pic2.jpg](https://raw.githubusercontent.com/wagiminator/Development-Boards/main/STC8H1K08_DevBoard/documentation/STC8H1K08_DevBoard_pic2.jpg) ![STC8H1K08_DevBoard_pic3.jpg](https://raw.githubusercontent.com/wagiminator/Development-Boards/main/STC8H1K08_DevBoard/documentation/STC8H1K08_DevBoard_pic3.jpg) # License ![license.png](https://i.creativecommons.org/l/by-sa/3.0/88x31.png) This work is licensed under Creative Commons Attribution-ShareAlike 3.0 Unported License. (http://creativecommons.org/licenses/by-sa/3.0/)
ID Name Designator Footprint Quantity Supplier JLCPCB Part Class Contributor
1 100n C1,C3,C4 C_0603 3 LCSC C14663 CC0603KRX7R9BB104
2 10u C2 C_0603 1 LCSC C19702 CC0603KRX7R9BB104
3 5817 D1 SCHOTTKY_SOD_323 1 LCSC C727114 SS54_C123946
4 HDR-M-2.54_1x10 H1,H2 210S-10X1/2.54 2 LCSC C57369 HDR-M-2.54_1x10
5 PWR LED1 LED0603 1 LCSC C72043 LED-0603-GREEN //image.lceda.cn/szlcsc/C72043.jpg
6 P34 LED2 LED0603 1 LCSC C2286 LED-0603-RED //image.lceda.cn/szlcsc/C2286.jpg
7 AO3401A Q1 SOT-23-3_W 1 LCSC C15127 AO3401A_C700954
8 1k R1,R2,R5 0603 3 LCSC C21190 Res_0603(1/10W)_EU
9 10k R3 0603 1 LCSC C25804 Res_0603(1/10W)_EU
10 RST SW1 SW-SMD_L4.0-W2.9-LS5.0 1 LCSC C967786 SW-4.0x2.9
11 STC8H1K08-36I-TSSOP20 U1 TSSOP-20 1 LCSC C915673 STC8H1K08-36I-TSSOP20
12 CH340E U2 MSOP-10 1 LCSC C99652 CH340E
13 Micro Input USB1 MINI-USB-SMD_U254-051T-4BH23-S2B 1 LCSC C319164 U254-051T-4BH23-S2B
