STD CH552G DAPLink
License: CC-BY-SA 3.0
  • 640
  • 0
  • 0
Update time: 2023-05-19 16:23:45
Creation time: 2023-05-05 17:51:42
# CH552 DAPLink The DAPLink, based on the CH552 microcontroller, is a debugging probe that follows the CMSIS-DAP standard. It supports both SWD and JTAG protocols, making it suitable for programming Microchip SAM and other ARM-based microcontrollers. In addition, it includes a Virtual COM Port (VCP) which adds an extra debugging capability. The SWD firmware is derived from [Ralph Doncaster's](https://github.com/nerdralph/ch554_sdcc/tree/master/examples/CMSIS_DAP) DAPLink implementation for CH55x microcontrollers, along with Deqing Sun's [CH55xduino](https://github.com/DeqingSun/ch55xduino) port. - Firmware (Github): https://github.com/wagiminator/CH552-DAPLink ![DAPLink_pic1.jpg](https://raw.githubusercontent.com/wagiminator/CH552-DAPLink/main/documentation/DAPLink_pic1.jpg) # CMSIS-DAP CMSIS-DAP provides a standardized way to access the Coresight Debug Access Port (DAP) of an ARM Cortex microcontroller via USB. CMSIS-DAP is generally implemented as an on-board interface chip, providing direct USB connection from a development board to a debugger running on a host computer on one side, and over JTAG (Joint Test Action Group) or SWD (Serial Wire Debug) to the target device to access the Coresight DAP on the other. As a USB HID compliant device, it typically does not require any drivers for the operating system. For more information refer to the [CMSIS-DAP Handbook](https://os.mbed.com/handbook/CMSIS-DAP). ![CMSIS-DAP.png](https://raw.githubusercontent.com/wagiminator/CH552-DAPLink/main/documentation/DAPLink_CMSIS-DAP.png) # Compiling and Installing Firmware ## Preparing the CH55x Bootloader ### Installing Drivers for the CH55x Bootloader On Linux you do not need to install a driver. However, by default Linux will not expose enough permission to upload your code with the USB bootloader. In order to fix this, open a terminal and run the following commands: ``` echo 'SUBSYSTEM=="usb", ATTR{idVendor}=="4348", ATTR{idProduct}=="55e0", MODE="666"' | sudo tee /etc/udev/rules.d/99-ch55x.rules sudo service udev restart ``` For Windows, you need the [CH372 driver](http://www.wch-ic.com/downloads/CH372DRV_EXE.html). Alternatively, you can also use the [Zadig Tool](https://zadig.akeo.ie/) to install the correct driver. Here, click "Options" and "List All Devices" to select the USB module, and then install the libusb-win32 driver. To do this, the board must be connected and the CH55x must be in bootloader mode. ### Entering CH55x Bootloader Mode A brand new chip starts automatically in bootloader mode as soon as it is connected to the PC via USB. Once firmware has been uploaded, the bootloader must be started manually for new uploads. To do this, the board must first be disconnected from the USB port and all voltage sources. Now press the BOOT button and keep it pressed while reconnecting the board to the USB port of your PC. The chip now starts again in bootloader mode, the BOOT button can be released and new firmware can be uploaded within the next couple of seconds. ## Compiling and Uploading using the makefile ### Installing SDCC Toolchain for CH55x Install the [SDCC Compiler](https://sdcc.sourceforge.net/). In order for the programming tool to work, Python3 must be installed on your system. To do this, follow these [instructions](https://www.pythontutorial.net/getting-started/install-python/). In addition [pyusb](https://github.com/pyusb/pyusb) must be installed. On Linux (Debian-based), all of this can be done with the following commands: ``` sudo apt install build-essential sdcc python3 python3-pip sudo pip install pyusb ``` ### Compiling and Uploading Firmware - Open a terminal. - Navigate to the folder with the makefile. - Connect the board and make sure the CH552 is in bootloader mode. - Run ```make flash``` to compile and upload the firmware. - If you don't want to compile the firmware yourself, you can also upload the precompiled binary. To do this, just run ```python3 ./tools/chprog.py daplink.bin```. # Operating Instructions Connect the DAPLink to the target board via the pin header. You can supply power via the 3V3 pin or the 5V pin (max 400 mA). Plug the DAPLink into a USB port on your PC. Since it is recognized as a Human Interface Device (HID), no driver installation is required. However, Windows users may need to install a CDC driver for the Virtual COM Port (VCP) using the [Zadig Tool](https://zadig.akeo.ie/). The DAPLink should work with any debugging software that supports CMSIS-DAP (e.g. OpenOCD or PyOCD). Of course, it also works with the [SAMD DevBoards](https://github.com/wagiminator/SAMD-Development-Boards) in the Arduino IDE (Tools -> Programmer -> Generic CMSIS-DAP). The virtual COM port (8N1 only) can be used with any serial monitor. # References, Links and Notes 1. [EasyEDA Design Files](https://oshwlab.com/wagiminator/ch552-swd-programmer) 2. [ARMmbed DAPLink](https://github.com/ARMmbed/DAPLink) 3. [CH55xduino](https://github.com/DeqingSun/ch55xduino) 4. [Ralph Doncaster's Implementation](https://github.com/nerdralph/ch554_sdcc/tree/master/examples/CMSIS_DAP) 5. [CMSIS-DAP Handbook](https://os.mbed.com/handbook/CMSIS-DAP) 6. [SDCC Compiler](https://sdcc.sourceforge.net/) 7. [CH55x SDK for SDCC](https://github.com/Blinkinlabs/ch554_sdcc) 8. [OpenOCD](http://openocd.org/) 9. [SAMD DevBoards](https://github.com/wagiminator/SAMD-Development-Boards) 10. [picoDAP](https://github.com/wagiminator/CH552-picoDAP) ![DAPLink_pic2.jpg](https://raw.githubusercontent.com/wagiminator/CH552-DAPLink/main/documentation/DAPLink_pic2.jpg) ![DAPLink_pic3.jpg](https://raw.githubusercontent.com/wagiminator/CH552-DAPLink/main/documentation/DAPLink_pic3.jpg) # License ![license.png](https://i.creativecommons.org/l/by-sa/3.0/88x31.png) This work is licensed under Creative Commons Attribution-ShareAlike 3.0 Unported License. (http://creativecommons.org/licenses/by-sa/3.0/)
ID Name Designator Footprint Quantity BOM_Supplier BOM_Supplier Part
1 100n C1 C_0603 1 LCSC C14663
2 10u C2 C_0603 1 LCSC C19702
3 1u C3,C4 C_0603 2 LCSC C15849
4 1A F1 F0603 1 LCSC C2757929
5 HDR H1 HDR-12-SIDE 1 LCSC C124388
6 PRG LED1 LED0603 1 LCSC C2286
7 PWR LED2 LED0603 1 LCSC C72043
8 10k R1 0603 1 LCSC C25804
9 1k R2,R3 0603 2 LCSC C21190
10 100R R4,R5,R6,R7,R8,R9,R10,R11 0603 8 LCSC C22775
11 BOOT SW1 SW-SMD_L4.0-W2.9-LS5.0 1 LCSC C465999
12 CH552G U1 SOP-16_150MIL 1 LCSC C111292
13 AP2112K-3.3TRG1 U2 SOT-25-5 1 LCSC C51118
14 USB-Plug USB1 USB-M-48 1 LCSC C112454
