STD ATtiny85 TinyFMradio SMD
License: CC-BY-SA 3.0
  • 14.1k
  • 11
  • 37
Update time: 2023-06-05 08:34:05
Creation time: 2019-05-04 10:47:27
# Overview TinyFMRadio is an ATtiny45/85 controlled FM radio with RDS (RDA5807) with an integrated audio amplifier (XPT8871 or TC8871), an OLED display (SSD1306) and a rotary encoder. You can directly connect a protected li-ion battery, a 3W / 4Ω speaker and an FM antenna. - Project Video (YouTube): https://youtu.be/dG5VVQmySEc - Firmware (Github): https://github.com/wagiminator/ATtiny85-TinyFMRadio ![pic1.jpg](https://raw.githubusercontent.com/wagiminator/ATtiny85-TinyFMRadio/master/documentation/TinyFMRadio_pic1.jpg) # Hardware The low-cost RDA5807MP is a single-chip broadcast FM stereo radio tuner with fully integrated synthesizer, IF selectivity, RDS/RBDS and MPX decoder. The tuner uses the CMOS process, support multi-interface and require the least external component. All these make it very suitable for portable devices. ![pic2.jpg](https://raw.githubusercontent.com/wagiminator/ATtiny85-TinyFMRadio/master/documentation/TinyFMRadio_pic2.jpg) # Software The firmware is just a demo sketch that implements basic functionality. By pressing the rotary encoder button the RDA5807 seeks the next radio station. Turning the rotary encoder increases/decreases the volume. Selected frequency and volume are stored in the EEPROM. Station name, frequency, signal strength, volume and battery state of charge are shown on an OLED display. ## I²C Implementation The I²C protocol implementation is based on a crude bitbanging method. It was specifically designed for the limited resources of ATtiny10 and ATtiny13, but should work with some other AVRs as well. Due to the low clock frequency of the CPU, it does not require any delays for correct timing. In order to save resources, only the basic functionalities which are needed for this application are implemented. For a detailed information on the working principle of the I²C implementation visit [TinyOLEDdemo](https://github.com/wagiminator/attiny13-tinyoleddemo). ## Controlling the RDA5807 The FM tuner IC RDA5807MP is controlled via I²C by the ATtiny. It has six writable 16-bit registers (addresses 0x02 - 0x07) and six readable 16-bit registers (addresses 0x0A - 0x0F). The RDA5807 has two methods of write access, a sequential one in which the registers are always written starting from address 0x02 and an indexed method in which the register address is transferred first and then the content. Both methods are determined by different I²C addresses. To transfer the 16-bit register content, the high byte is sent first. The RDA5807 is controlled by setting or clearing certain bits in the respective registers. The details of the meanings of the individual registers can be found in the data sheet. The current register contents are saved in the RDA_regs arrays. The RDA implementation is based on the work of [Maarten Janssen](https://hackaday.io/project/9009-arduino-radio-with-rds). ## Rotary Encoder Implementation The implementation for the rotary encoder uses pin change interrupts on only one of the pins and is written in such a way that bouncing is automatically suppressed. ## Compiling and Uploading the Software ### If using the Arduino IDE - Make sure you have installed [ATtinyCore](https://github.com/SpenceKonde/ATTinyCore). - Go to **Tools -> Board -> ATtinyCore** and select **ATtiny25/45/85 (No bootloader)**. - Go to **Tools** and choose the following board options: - **Chip:** ATtiny45 or ATtiny85 - **Clock:** 1 MHz (internal) - **B.O.D.:** disabled - Leave the rest at the default settings - Connect your programmer to your PC and to the ICSP header of the device. - Go to **Tools -> Programmer** and select your ISP programmer (e.g. [USBasp](https://aliexpress.com/wholesale?SearchText=usbasp)). - Go to **Tools -> Burn Bootloader** to burn the fuses. - Open TinyFMRadio sketch and click **Upload**. ### If using the precompiled hex-file - Make sure you have installed [avrdude](https://learn.adafruit.com/usbtinyisp/avrdude). - Connect your programmer to your PC and to the ICSP header of the device. - Open a terminal. - Navigate to the folder with the hex-file. - Execute the following command (if necessary replace "t85" with your chip and "usbasp" with the programmer you use): ``` avrdude -c usbasp -p t85 -U lfuse:w:0x62:m -U hfuse:w:0xd7:m -U efuse:w:0xff:m -U flash:w:tinyfmradio.hex ``` ### If using the makefile (Linux/Mac) - Make sure you have installed [avr-gcc toolchain and avrdude](http://maxembedded.com/2015/06/setting-up-avr-gcc-toolchain-on-linux-and-mac-os-x/). - Connect your programmer to your PC and to the ICSP header of the device. - Open the makefile and change the chip if you are not using ATtiny85 and the programmer if you are not using usbasp. - Open a terminal. - Navigate to the folder with the makefile and the Arduino sketch. - Run "make install" to compile, burn the fuses and upload the firmware. # References, Links and Notes 1. [ATtiny25/45/85 Datasheet](https://ww1.microchip.com/downloads/en/DeviceDoc/Atmel-2586-AVR-8-bit-Microcontroller-ATtiny25-ATtiny45-ATtiny85_Datasheet.pdf) 2. [RDA5807MP Datasheet](https://datasheet.lcsc.com/szlcsc/1806121226_RDA-Microelectronics-RDA5807MP_C167245.pdf) 3. [SSD1306 Datasheet](https://cdn-shop.adafruit.com/datasheets/SSD1306.pdf) 4. [TC8871 Datasheet](https://datasheet.lcsc.com/lcsc/2010160933_Shenzhen-Fuman-Elec-TC8871_C89482.pdf) 5. [ATtiny13 TinyPocketRadio](https://github.com/wagiminator/ATtiny13-TinyPocketRadio) ![pic3.jpg](https://raw.githubusercontent.com/wagiminator/ATtiny85-TinyFMRadio/master/documentation/TinyFMRadio_pic3.jpg) # License ![license.png](https://i.creativecommons.org/l/by-sa/3.0/88x31.png) This work is licensed under Creative Commons Attribution-ShareAlike 3.0 Unported License. (http://creativecommons.org/licenses/by-sa/3.0/)
1 Header VIN,SPK HDR-1X2/2.54 2
2 HT7333-A U4 SOT-89 1
3 32.768 khz Y1 XTAL-32KHZ 1
4 I2C I2C HDR-4X1/2.54 1
5 1000uF C3 CAP-SMD_D10.0-L10.3-W10.3-H10.2 1
6 1k R2 0603 1
7 10k R7,R1,R8,R9 0603 4
8 20k R6,R5 0603 2
9 4k7 R3,R4 0603 2
10 ATTINY85-20SU U1 SOIC-8_208MIL 1
11 Slide Switch POWER SLIDE SWITCH DPDT 1P2T JB 1
12 ICSP-6 ICSP ICSP-6 1
13 Rotary Enc SW1 BOURNS_PEC11R-4XXXF-SXXXX 1
14 Header ANT HDR-1X1/2.54 1
15 10u C7,C4 0603 2
16 100n C1,C8,C15,C14,C5,C16,C6 0603 7
17 1u C9,C11 0603 2
18 1n C10 0603 1
19 390n C12,C13 0603 2
20 47u C2 1206 1
21 XPT8871ES U3 HSOP-8 1
22 LED-Blue LED1 LED-0603 1
23 RDA5807MP U2 SOP-8_150MIL 1
