STD ATtiny85 TinyCharger
License: CC-BY-SA 3.0
  • 8.8k
  • 2
  • 29
Update time: 2022-04-09 04:47:17
Creation time: 2021-02-20 20:10:21
# Overview TinyCharger is an ATtiny25/45/85-based, single-cell Li-ion battery charger with selectable charging current limit (100mA - 1000mA) and an OLED display for monitoring. - Project Video (Youtube): https://youtu.be/JtS_8n5oOiI - Firmware (Github): https://github.com/wagiminator/ATtiny85-TinyCharger ![pic1.jpg](https://raw.githubusercontent.com/wagiminator/ATtiny85-TinyCharger/main/documentation/TinyCharger_pic1.jpg) # Hardware ## Power Connectors The device is equipped with a Micro-USB and a USB-C connector for power supply. Only one connector can be used at a time. The supply voltage must be 5V. ## Battery Connectors The device is equipped with a JST-PH 2.0mm socket and a 2.54mm pin header for connection to the battery. Only one battery can be charged at a time. ## Battery Charger For battery charging the [TP4056](https://datasheet.lcsc.com/szlcsc/1904031009_TPOWER-TP4056_C382139.pdf) is used. The TP4056 is a complete constant-current/constant-voltage linear charger for single-cell lithium-ion batteries. The maximum charge voltage is fixed at 4.2V and the charge current can be programmed externally with a resistor. The total resistance is determined by three resistors connected in parallel, two of which can be switched on and off by the ATtiny via MOSFETs. The TP4056 automatically terminates the charge cycle when the charge current drops to 1/10th the programmed value after the final float voltage is reached. Other features include current monitor, under voltage lockout and automatic recharge. ## Voltage and Current Measurement An [INA219](https://www.ti.com/lit/ds/symlink/ina219.pdf) is used to measure voltage and current. The INA219 is a current shunt and power monitor with an I²C-compatible interface. The device monitors both shunt voltage drop and bus supply voltage, with programmable conversion times and filtering. A programmable calibration value, combined with an internal multiplier, enables direct readouts of current in amperes. The selected shunt resistance of 8mΩ enables both a very small influence on the circuit and a measurement with a resolution of 1mA. For an accurate measurement, a shunt resistor with a low tolerance (1% or better) should be selected. ## User Interface The user interface utilizes two buttons and a [128x64 pixels OLED display](http://aliexpress.com/wholesale?SearchText=128+64+0.96+oled+new+4pin). An [ATtiny25/45/85](https://ww1.microchip.com/downloads/en/DeviceDoc/Atmel-2586-AVR-8-bit-Microcontroller-ATtiny25-ATtiny45-ATtiny85_Datasheet.pdf) microcontroller handles the user interface as well as the control and monitoring of the charging functions. ![pic4.jpg](https://raw.githubusercontent.com/wagiminator/ATtiny85-TinyCharger/main/documentation/TinyCharger_pic4.jpg) # Software ## Basic Principle The charging current is programmed via a resistor, the value of which can be set by the ATtiny via two MOSFETs and changed by pressing the SET button. An INA219 continuously measures the charging current and voltage and transmits the values to the ATtiny via I2C. From this, the ATtiny calculates the state of charge and capacity and displays the values on the OLED screen. ## I²C OLED Implementation The I²C protocol implementation is based on a crude bitbanging method. It was specifically designed for the limited resources of ATtiny10 and ATtiny13, but it works with some other AVRs (including the ATtiny25/45/85) as well. The functions for the OLED are adapted to the SSD1306 OLED module, but they can easily be modified to be used for other modules. In order to save resources, only the basic functionalities which are needed for this application are implemented. For a detailed information on the working principle of the I²C OLED implementation visit [TinyOLEDdemo](https://github.com/wagiminator/attiny13-tinyoleddemo). ## Accuracy of Time and Capacity Determination The internal oscillator of the ATtiny is used to determine the charging time and the electric charge. The accuracy of the internal oscillator is +/-10% with the factory calibration. This can be improved to +/-2% or better by [manual calibration](https://github.com/wagiminator/ATtiny84-TinyCalibrator). The calibration value determined in this way can be set in the source code. In addition to the time measurement, the internal resistance of the battery being charged also plays a role for the accuracy of the calculated capacity. Due to these factors, the displayed capacity is only a rough estimate. ## Compiling and Uploading Since there is no ICSP header on the board, you have to program the ATtiny either before soldering using an [SOP adapter](https://aliexpress.com/wholesale?SearchText=sop-8+150mil+adapter), or after soldering using an [EEPROM clip](https://aliexpress.com/wholesale?SearchText=sop8+eeprom+programming+clip). The [AVR Programmer Adapter](https://github.com/wagiminator/AVR-Programmer/tree/master/AVR_Programmer_Adapter) can help with this. ### If using the Arduino IDE - Make sure you have installed [ATtinyCore](https://github.com/SpenceKonde/ATTinyCore). - Go to **Tools -> Board -> ATtinyCore** and select **ATtiny25/45/85 (No bootloader)**. - Go to **Tools** and choose the following board options: - **Chip:** ATtiny25 or 45 or 85 (depending on your chip) - **Clock:** 1 MHz (internal) - **B.O.D.Level:** B.O.D. enabled (2.7V) - Leave the rest at the default settings - Connect your programmer to your PC and to the ATtiny. - Go to **Tools -> Programmer** and select your ISP programmer (e.g. [USBasp](https://aliexpress.com/wholesale?SearchText=usbasp)). - Go to **Tools -> Burn Bootloader** to burn the fuses. - Open TinyCharger sketch and click **Upload**. ### If using the precompiled hex-file - Make sure you have installed [avrdude](https://learn.adafruit.com/usbtinyisp/avrdude). - Connect your programmer to your PC and to the ATtiny. - Open a terminal. - Navigate to the folder with the hex-file. - Execute the following command (if necessary replace "t85" with your chip and "usbasp" with the programmer you use): ``` avrdude -c usbasp -p t85 -U lfuse:w:0x62:m -U hfuse:w:0xd5:m -U efuse:w:0xff:m -U flash:w:tinycharger.hex ``` ### If using the makefile (Linux/Mac) - Make sure you have installed [avr-gcc toolchain and avrdude](http://maxembedded.com/2015/06/setting-up-avr-gcc-toolchain-on-linux-and-mac-os-x/). - Connect your programmer to your PC and to the ICSP header of the device. - Open the makefile and change the chip if you are not using ATtiny85 and the programmer if you are not using usbasp. - Open a terminal. - Navigate to the folder with the makefile and the Arduino sketch. - Run "make install" to compile, burn the fuses and upload the firmware. # Operating Instructions 1. Connect the device via the Micro-USB or USB-C port to a 5V power supply that can provide sufficient current. 2. Use the SET button to select the maximum charging current. Note that it can overshoot by a few milliamperes! 3. Connect the Li-Ion battery to one of the battery connectors. Pay attention to the correct polarity! 4. The battery is charged immediately. The SET button is locked during the charging process to prevent the charging current from being changed accidentally. The charging process stops automatically when the battery is fully charged. The total charging time and the charged capacity remain displayed as long as the device is supplied with power. These values can be reset using the RESET button. ![pic5.jpg](https://raw.githubusercontent.com/wagiminator/ATtiny85-TinyCharger/main/documentation/TinyCharger_pic5.jpg) # Characteristics |Parameter|Value| |:-|:-| |Supply Voltage|4.3 - 5.5V| |Charge Voltage Limit|4.2V| |Charge Current Limits|100, 350, 750, 1000mA (selectable)| |Voltage Measurement Resolution|4mV| |Current Measurement Resolution|1mA| # References, Links and Notes 1. [ATtiny25/45/85 Datasheet](https://ww1.microchip.com/downloads/en/DeviceDoc/Atmel-2586-AVR-8-bit-Microcontroller-ATtiny25-ATtiny45-ATtiny85_Datasheet.pdf) 2. [TP4056 Datasheet](https://datasheet.lcsc.com/szlcsc/1904031009_TPOWER-TP4056_C382139.pdf) 3. [INA219 Datasheet](https://www.ti.com/lit/ds/symlink/ina219.pdf) 4. [SSD1306 Datasheet](https://cdn-shop.adafruit.com/datasheets/SSD1306.pdf) ![pic2.jpg](https://raw.githubusercontent.com/wagiminator/ATtiny85-TinyCharger/main/documentation/TinyCharger_pic2.jpg) ![pic3.jpg](https://raw.githubusercontent.com/wagiminator/ATtiny85-TinyCharger/main/documentation/TinyCharger_pic3.jpg) # License ![license.png](https://i.creativecommons.org/l/by-sa/3.0/88x31.png) This work is licensed under Creative Commons Attribution-ShareAlike 3.0 Unported License. (http://creativecommons.org/licenses/by-sa/3.0/)
1 OLED 0.91 OLED I2C OLED 0.91 1
2 RESET SW1 SW-SMD_TS24CA 1
3 SET SW2 SW-SMD_TS24CA 1
4 1k R5,R11,R10,R6 0603 4
5 5k1 R13,R12,R8 0603 3
6 10k R1,R4,R3 0603 3
7 1k8 R9 0603 1
8 12k R7 0603 1
9 TP4056 U3 SOP-8_EP_150MIL 1
10 CHRG LED1 LED0603 1
11 ATtiny85 U1 SOIC-8_208MIL 1
12 USB PWR USB1 USB PWR CONNECTOR 1
13 USB-TYPE-C-6PIN USB2 USB-C-SMD-6P 1
14 DONE LED2 LED0603 1
15 INA219 U2 SOT-23-8 1
16 100n C1,C3,C4 0603 3
17 10u C2 0603 1
18 HDR-M-2.54_1x2 J1 210S-2X1/2.54 1
19 PH-2AW RHOS P1 CONN-TH_2P-P2.00_PH-2AW 1
20 R008 R2 2512 1
21 AO3400A Q2,Q1 SOT-23-3_L2.9-W1.6-P1.90-LS2.8-BR 2
