Your EasyEDA usage duration is brief. In order to avoid advertising information, this action is not supported at present. Please extend your EasyEDA usage duration and try again.
Editor Version×
# Overview
HV UPDI (High Voltage Unified Program and Debug Interface) programmer for the new megaAVR 0-, tinyAVR 0- and 1-series microcontrollers built on ATmega8/88/168/328 based on the design and the firmware by Dlloydev ([https://github.com/Dlloydev/jtag2updi](https://github.com/Dlloydev/jtag2updi)). The HV UPDI programmer will enable you to use the additional configuration settings for the UPDI pin without the fear of getting locked out from the MCU. It features 3 programming modes: UPDI, HV or PCHV, with the target voltage at 5V.
# Operating Instructions
**Mode Jumper Settings:**
| Mode Jumper | Prog Mode | PA0 Configurations | HV Pulse | Power Cycle |
| no jumper | UPDI | UPDI | NO | NO |
| pins 2-3 shorted | HV | UPDI, RESET | YES | NO |
| pins 1-2 shorted | PCHV | UPDI, RESET, GPIO | YES | YES |
**Modes:**
| Mode | Function |
| UPDI Mode | This mode would be used when the UPDI pin is configured as UPDI or for any target device that isn't HV tolerant. |
| HV Mode | This mode applies the 12V UPDI enable sequence (HV pulse) at the start of the programming sequence. This temporarily reconfigures the UPDI/Reset pin to UPDI mode which will remain in this state until the next power on reset (POR). This allows programming to occur when the pin is configured as Reset. A POR needs to occur for any fuse setting changes to take effect. |
| PCHV Mode | Power Cycle High Voltage mode (PCHV) will initiate a power cycle and HV pulse at the start of the programming sequence. At the end of the sequence, a second power cycle will occur which causes any new fuse setting to take effect. The power cycle OFF duration has been set to 10ms. This mode would be used when the UPDI/Reset pin is configured as Reset or as GPIO. |
**Status LED Operation:**
| LED | Status |
| PWR | STEADY ON when programmer is powered |
| PRG | STEADY ON when in programming mode; BLINKING at 4Hz if target overload occurs |
| HV | FLASHING at HV pulses during programming |
![IMG_20200816_165418_x.jpg](//image.easyeda.com/pullimage/WSaYBqbKyEx85czv25Vj6bLIZKI5R4EZFXKvWk67.jpeg)
![IMG_20200820_165012_x.jpg](//image.easyeda.com/pullimage/MiPS7JxxDo3wv8L5noEuWbKuNfCzOo8h9CAsPrfS.jpeg)
![pic_17_2.jpg](//image.easyeda.com/pullimage/looVl4c4DJbB6DBh1GLoLdgY8OiKGK0J3UIYaWCC.jpeg)
# References, Links and Notes
* More information and source code: [https://github.com/Dlloydev/jtag2updi](https://github.com/Dlloydev/jtag2updi)
* Getting started with the new ATtiny chips: http://www.technoblogy.com/show?2OCH
* megaTinyCore: https://github.com/SpenceKonde/megaTinyCore
* MegaCoreX: https://github.com/MCUdude/MegaCoreX
* UPDI Programmer based on ATmega8/88/168/328: https://easyeda.com/wagiminator/y-updi-programmer
* Mini UPDI Programmer based on ATtiny1604: https://easyeda.com/wagiminator/attiny1604-updi-programmer
* Mini UPDI HV Programmer based on ATtiny1604: https://easyeda.com/wagiminator/attiny1604-updi-hv-programmer
* Development board for ATtiny x14/x04 series: https://easyeda.com/wagiminator/attiny-814-development-board-smd
* Development board for ATtiny x16/x06 series: https://easyeda.com/wagiminator/y-attiny3216-development-board-smd
* Development board for ATmega4808 series: https://easyeda.com/wagiminator/atmega4808-development-board_copy
Forked project will be set private in personal workspace. Do you continue?
Project
The Pro editor is about to be opened to save as. Do you want to continue?
private message
Send message to wagiminator
Delete
Are you sure to delete the comment?
ATmega UPDI HV Programmer
High-Voltage UPDI Programmer for megaAVR and tinyAVR Microcontrollers
Announcer: Stefan Wagner
Creation time: 2020-07-26 18:17:29
Published time:
2021-11-23 08:24:16
Report type:
Please select report type
Report reason:
Please fill in the reason for your report and the content is 2-1000
words
Upload image:
Upload image
Email address:
Please fill in your email address
Report type:
Report reason:
words
Upload image:
Upload image
Email address:
Submitted successfully! The review result can be viewed in the personal
center, review notification.
Kind tips
Project
Copy
Copy
Scan the QR code and open it on the mobile terminal
