STD SENTSOR CORE ESP32-EMBED
License: CC-BY-SA 3.0
  • 8.6k
  • 0
  • 46
Update time: 2024-04-22 03:54:59
Creation time: 2021-01-09 12:10:10
- **Compact & powerful**, measured only 58.42x40.64mm (2300x1600mil) packing all the onboard features. - **2x18P pinout layout**, standard pitch 2.54mm (100mil) breadboard friendly, with one side dedicated for peripheral (power, programming, communication) and the other side for GPIO, simplifying wire/trace management. - **Castellated holes & pin header**, choose inter-board connection method according to your application requirement. - **ESP32-WROOM-32UE**, comes with latest [ECO V3](https://www.espressif.com/sites/default/files/documentation/ESP32_ECO_V3_User_Guide__EN.pdfhttps://www.espressif.com/sites/default/files/documentation/ESP32_ECO_V3_User_Guide__EN.pdf) Dual Core 32-bit LX6 microprocessor with clock up to 240MHz, ULP co-processor, 520kB SRAM, 4MB flash. - **802.11b/g/n WiFi Connectivity**, support mode STA/AP/STA+AP mode with external antenna using U.FL/IPEX connector allowing the board to be installed inside the enclosure without worrying transceiver signal quality. - **Bluetooth 4.2 Connectivity**, support classic bluetooth and Low Energy (LE) protocol. - **DS3231M RTC**, extremely accurate ±5ppm RTC with alarm trigger capability and replaceable CR1220 battery. Connected via I2C at address 0x68. - **Auto-reset Trigger**, ease boot mode changing during firmware upload process using DTR & RTS control line. - **Battery Powered**, run SENTSOR board everywhere without power supply issue with 1-cell Lithium Ion/Polymer battery via JST-PH connector. - **CN3165 Battery Charger**, solar-powered and USB-compatible Li-Ion/Polymer charger with on-chip adaptive charging current for wide range of input power scenario. - **DW01A Battery Protection**, battery usage protection against over-charge, over-discharge, over-current, and short circuit. - **LC709203F Battery Fuel Gauge**, accurately monitor your battery Relative State of Charge (RSOC). - **RT9078 & RT9013 LDO**, dual low quiescent current LDO design providing configurable +3.3V power rail up to 800mA. - **Super Low Power**, measured sleep mode power consumption down to XuW (XuA XV at VBAT pin, LDO2 off). - **Built-in LED/RGB**, single color active-low LED connected to pin IO2, and SK6812 addressable RGB LED connected to pin IO4. SK6812 data out is exposed so you can chain it up with the rest of the LED circuit. - **MicroSD socket**, connected via SPI with slave select (SS) at pin IO5. - **26 pin GPIO** @3V3 level, 3xUART, 2xSPI, 2xI2C, 2xI2S, 12bit ADC, 8bit DAC, hall-effect sensing, capacitive sensing, JTAG debug, etc.
ID Name Designator Footprint Quantity BOM_Supplier BOM_Manufacturer BOM_Manufacturer Part BOM_Supplier Part
1 CR1220 BAT1 BATTERY-2-AA 1 LCSC Q&J CR1220-2 C70381
2 RST BTN1 SW-SMD_L3.9-W3.0-P4.45 1 LCSC XUNPU TS-1088R-02026 C455280
3 BOOT BTN2 SW-SMD_L3.9-W3.0-P4.45 1 LCSC XUNPU TS-1088R-02026 C455280
4 1u C1,C2,C4,C7 C0402 4 LCSC SAMSUNG CL05A105KO5NNNC C29266
5 10u C3,C5,C8 C0402 3 LCSC Samsung Electro-Mechanics CL05A106MP5NUNC C315248
6 100n C6,C9,C10,C11,C12,C13 C0402 6 LCSC YAGEO CC0402KRX7R7BB104 C60474
7 220u, 6.3V C14 CASE-B_3528 1 LCSC AVX F930J227MBA C145083
8 HYC80-TF08-375 CARD1 HYC80-TF08-XXX 1 DZYJZJ Shenzhen Huayu Chuang Precision Electronics Co., Ltd. HYC80-TF08-XXX HYC003993
9 JST-PH, 2P CN1 CONN-SMD_2P-P2.00_A2001WR-S-2P-AA 1 LCSC CNJM A2001WR-S-2P C375128
10 BAT60A D1 SOD-323_L1.8-W1.3-LS2.5-RD 1 LCSC Infineon Technologies BAT60AE6327HTSA1 C117485
11 Blue LED1 LED-0402 1 LCSC EVERLIGHT 16-213/BHC-AN1P2/3T C131223
12 Green LED2 LED-0402 1 LCSC EVERLIGHT 16-213/GHC-YR1S1/3T C74338
13 Orange LED3 LED-0402 1 LCSC EVERLIGHT 16-213UYOC/S530-A2/TR8 C88330
14 White LED4 LED-0402 1 LCSC EVERLIGHT 16-213/T3D-AP1Q2QY/3T C74340
15 EC20-SK6812 LED5 SK6812-2020 1 Normand Normand EC20-6812 EC20-6812
16 CJ2301 Q1 SOT-23-3_L3.0-W1.7-P0.95-LS2.9-BR 1 LCSC CJ CJ2301 S1 C8547
17 SL8205S Q3 SOT-23-6_L2.9-W1.6-P0.95-LS2.8-BL 1 LCSC SLKORMICRO Elec. SL8205S C359990
18 UMH3N Q4 SC-70-6_L2.2-W1.3-P0.65-LS2.1-BL 1 LCSC CJ UMH3N C62892
19 100k R1,R2,R3 R0402 3 LCSC YAGEO RC0402FR-07100KL C60491
20 1k R5,R8,R9,R18 R0402 4 LCSC YAGEO RC0402FR-071KL C106235
21 2.2k R6 R0603 1 LCSC YAGEO RC0603JR-072K2L C113303
22 100 R7 R0402 1 LCSC YAGEO RC0402FR-07100RL C106232
23 10k R10,R11,R12,R13,R14,R15,R16,R17 R0402 8 LCSC YAGEO RC0402FR-0710KL C60490
24 0 R20 R0402 1 LCSC YAGEO RC0402FR-070RL C106231
25 0 (NC) R21 R0402 1 LCSC YAGEO RC0402FR-070RL C106231
26 RT9078-33GJ5 U1 TSOT-23-5_L2.9-W1.6-P0.95-LS2.8-BL 1 LCSC Richtek Tech RT9078-33GJ5 C110427
27 RT9013-33GB U2 TSOT-23-5_L2.9-W1.6-P0.95-LS2.8-BL 1 LCSC RICHTEK RT9013-33GB C47773
28 CN3165 U3 DFN-8_L3.0-W3.0-P0.50-TL-EP 1 LCSC ShangHai Consonance Elec CN3165 C559035
29 DW01A U4 SOT-23-6_L2.9-W1.6-P0.95-LS2.8-BL 1 LCSC TuoFeng DW01A C436931
30 LC709203FQH-01TWG U5 WDFN-8_L4.0-W3.0-P0.50-BL-EP 1 LCSC ON Semicon LC709203FQH-01TWG C152311
31 ESP32-WROOM-32U/UE U6 WIFIM-32UE-SMD_38P-L19.2-W18.0-P1.27 1 LCSC Espressif Systems ESP32-WROOM-32UE(4MB) C701344
32 DS3231MZ+ U7 SOIC-8_L4.9-W3.9-P1.27-LS6.0-BL 1 LCSC MAXIM DS3231MZ+ C107410
