STD Olimex ESP32-EVB Dual Fan Add-On
License: Public Domain
  • 86
  • 0
  • 0
Update time: 2024-02-08 23:35:32
Creation time: 2024-02-08 19:20:15
This is an untested add-on board for Olimex ESP32-EVB for controlling two standard 12V four-pin PWM fans.
In addition to controlling the fan PWM and observing the fan RPMs (via tachometer inputs; two pulses per rotation), one or both fans can be powered down completely.
On the PCB, the two Vishay SI2393DS-T1-GE3 P-channel MOSFETs in SOT23-3 are marked as G6, the six Nexperia NX138AKR N-channel MOSFETs also in SOT23-3 are marked as AP, the four 220Ω resistors in 0603 as 221, and the six 10kΩ resistors in 0603 as 103.  These should match the markings on the corresponding components themselves.
There are two 3mm holes for mounting, their center-to-center distance being 45mm.
ID Name Designator Footprint Quantity Supplier JLCPCB Part Class
1 MX126-5.0-GN01-02P-CU-S-A CN1 CONN-TH_2P-P5.00_MX126-5.0-GN01-02P-CU-S-A 1 LCSC C5188434 MX126-5.0-GN01-02P-CU-S-A
2 HDR-F-2.54_2x3 EXT1-7-12,EXT1-35-40 HDR-F-2.54_2X3 2 LCSC C65114 HDR-F-2.54_2x3
3 47053-1000 FAN1,FAN2 CONN-TH_47053-1000 2 LCSC C240840 47053-1000
4 NX138AKR Q1,Q2,Q3,Q4,Q6,Q8 TO-236AB_L2.9-W1.3-P0.95-LS2.3-BR 6 LCSC C551585 NX138AKR
5 SI2393DS-T1-GE3 Q5,Q7 SOT-23-3_L2.9-W1.3-P1.90-LS2.4-BR 2 LCSC C5273032 SI2393DS-T1-GE3
6 220Ω R1,R2,R8,R10 R0603 4 LCSC C327834 MR06X221JTL
7 10kΩ R3,R4,R5,R6,R7,R9 R0603 6 LCSC C68804 TC0310F1002T5E
