STD Hedphone amp TPA6120 for the BRZHIFI BZ2204E series case, from Aliexpress.
License: Public Domain
  • 7.4k
  • 5
  • 12
Update time: 2023-11-20 05:43:25
Creation time: 2021-01-23 07:04:17
Headphone amplifier based on a specialized TPA6120 chip with a pre-amplifier based on OPA2134P. This is a headphone amplifier with high sound quality. TPA6120 provides high bandwidth, extremely low noise and dynamic range up to 128dB. Pre-amplifier circuit from Lehmann Audio Black Cube Linear - clone. Power supply from a transformer with a midpoint 2x15V.
Specifications
Band of reproducible frequencies 10-20000 Hz
Signal to noise ratio: 128dB
Crosstalk: -112 dB
Total Harmonic Distortion: 0.0006
The printed circuit board is designed for an aluminum case of the BRZHIFI BZ2204E series (can be purchased at Aliexspress at the link https://aliexpress.ru/item/2002062999.html?spm=a2g0s.9042311.0.0.264d33edDuel89&_ga=2.66139182.1817210424.1618018913-1588942387.1614749566 )
Features:
The AC voltage input is maximally shifted to the right edge of the board, for a minimum of interference to the input circuits. It is also recommended to locate the power transformer away from the input circuits located on the left side of the printed circuit board.
Power transformer 2x15V I highly recommend toroidal. You can use TTP-10 230V / 2x15V from the manufacturer Torel (can be purchased here http://www.torel.ru/products/transformers.php?SECTION_ID=262 at the time of ordering on 21.01.2020 the transformer cost 470 rubles and postage 450 rubles ) R1 and R2 in the power supply significantly reduce ripple. The polygon on the upper and lower sides of the printed circuit board significantly reduces the impulse interconnections, blocking the input circuits from pickups. In the lower left corner of the PCB, there is a grounding pin of the metal case of the headphone amplifier, which effectively reduces noise. A 12-volt RY-12W-K Fujitsu relay is used as a switch between two inputs from a DAC or a line input. To facilitate the temperature control and efficient heat dissipation from the TPA6120 microcircuit, it is advisable to use a heatsink of a suitable size. It is necessary to independently drill 2 holes in the radiator and cut a thread for a 3.0mm bolt. The distance between the holes is 20 mm. Double variable resistor 10 kOhm from the manufacturer ALPs type RK27. Capacitors C24 and C25 are film capacitors with the lowest ECR at 2.2 mF, the distance between the legs is 15 mm. EPCOS can be used.
Усилитель для наушников на специализированной микросхеме TPA6120 с предварительным усилителем на OPA2134P. Это усилитель для наушников с высоким качеством звука. TPA6120 обеспечивает высокую пропускную способность, чрезвычайно низкий уровень шума и динамический диапазон до 128 дБ.Схема предварительного усилителя от Lehmann Audio Black Cube Linear - clone. Питание от трансформатора с средней точкой 2х15В.
Технические характеристики
Полоса воспроизводимы частот 10-20000 Гц
Отношение сигнал/шум: 128 дБ
Переходные помехи: -112 дБ
Коэффициент нелинейных искажений:  0.0006
Печатная плата спроектирована под алюминиевый корпус серии BRZHIFI BZ2204E ( можно приобрести на Алиэкспресс по ссылке https://aliexpress.ru/item/2002062999.html?spm=a2g0s.9042311.0.0.264d33edDuel89&_ga=2.66139182.1817210424.1618018913-1588942387.1614749566 )
Особенности:
Вход переменного напряжения максимально сдвинут в правую крайнюю часть платы, для минимума наводок на входные цепи. Трансформатор питания рекомендуется также распологать подальше от входных цепей находящихся в левой части печатной платы.
Трансформатор питания 2х15В настоятельно рекомендую тороидальный. Можно применить ТТП-10  230В / 2х15В от производителя Торел ( можно приобрести здесь http://www.torel.ru/products/transformers.php?SECTION_ID=262 на момент заказ 21.01.2020г. трансформатор стоил 470 рублей а почтовые расходы 450 рублей) R1 и R2 в блоке питания предназначены для понижения пульсаций. Полигон с верхней и нижней стороны печатной платы значительно понижает импульсные помехи, прекрывая входные цепи от наводок. В левом нижнем углу печатной платы находится контакт заземления металлического корпуса усилителя наушников, что эффективно понижает наводки. В качестве коммутатора двух входов с ЦАП или линейного входа используется реле RY-12W-K Fujitsu на 12 вольт. Для облегчения температурного режима и эффективного отвода тепла от микросхемы TPA6120 желательно использовать радиатор подходящего размера. Необходимо самостоятельно в радиаторе просверлить 2 отверстия и нарезать резьбу под болт на 3.0мм. Расстояние между отверстиями 20 мм. Сдвоенный переменный резистор на 10 кОм от производителя ALPs тип RK27. Конденсаторы C24 и C25 плёночные с максимально низким ECR на 2,2 мФ расстояние между ножками 15 мм. Можно применить EPCOS.
1 100n C1,C2,C3,C4,C19,C20,C21,C22 CAP-TH_L7.2-W2.5-P5.00-D0.5 8
2 4700uF C5,C6 CAP-TH_BD18.0-P7.50-D1.2-FD 2
3 100nF C7,C8,C12,C15,C23 CAP-TH_L7.2-W2.5-P5.00-D0.5 5
4 150nF C9,C10 CAP-TH_L7.2-W2.5-P5.00-D0.5 2
5 100u/25V C11,C16 CAP_EL_D6.3XF2.5 2
6 100p C13,C14 C0805 2
7 470u/25V C17,C18 CAP-D10.0×F5.0 2
8 2.2uF C24,C25 CAP-SC_12.5X7-P15 2
9 KBP310 D1 DIO-BG-TH_KBP 1
10 Light-emitting diode (LED) D2 LED-TH_BD4.6-P2.54-L-RD 1
11 Light-emitting diode (LED) D3 LED-TH_BD3.0_GREEN 1
12 HDR-M-3.2-1x1 J1 КОНТАКТ ЗАЗЕМЛЕНИЯ 1
13 RY-12W-K K1 RELAY-TH_RY-XXW-K 1
14 230/115VAC P1 B5B-XH-A_3PIN_HIV 1
15 DAC IN P2 CONN-TH_1.25T-4A 1
16 LINE IN P3 CONN-TH_1.25T-4A 1
17 NEUTRIK NMJ6F / NRJ6F P4 NEUTRIK NMJ6F 1
18 PREAMP OUT P5 CONN-TH_1.25T-4A 1
19 AC 15V P6 CONN-TH_4P-P2.54_KF2510-4A 1
20 1.25T-4A P7 CONN-TH_1.25T-4A 1
21 1.25T-2A P8 CONN-TH_1.25T-2A 1
22 1.5 / 1W R1,R2 RES-TH_BD4.0-L11.5-P15.50-D0.7 2
23 1.1k R3,R4 R0805 2
24 100 R5,R6 R0805 2
25 10k R7,R8,R21,R22 R0805 4
26 2.2k R9,R10 R0805 2
27 680 R11,R12 R0805 2
28 47 R13,R14 R1206 2
29 4.7k R15,R16 R0805 2
30 47 R17,R18 R0805 2
31 51 R19,R20 R0805 2
32 1k R23,R24,R27,R28 R0805 4
33 10 / 1W R25,R26 RES-TH_BD4.0-L11.5-P15.50-D0.7 2
34 100 R29 RES-TH_BD2.2-L6.5-P10.50-D0.6 1
35 15k R30 RES-TH_BD2.2-L6.5-P10.50-D0.6 1
36 240 / 1W R31 RES-TH_BD4.0-L11.5-P15.50-D0.7 1
37 7.5K R32 R0805 1
38 10k Log RP1 RES-ADJ-TH_RK27112A00CC 1
39 SW_DIP-2 SW1,SW2 EDG-02 2
40 SWITCH DAC/Line SW3 SWITCH RELEY 1
41 Transformer T1 YHDC_PTC35 1
42 LM317 U1 TO220_WITH_15X10X25_HEATSINK 1
43 LM337 U2 TO220_WITH_15X10X25_HEATSINK 1
44 TPA6120A2DWP U4 HSOP-20_L12.9-W10.6-P1.27-BL-EP 1
45 OPA2134PA U3 DIP-8_L9.7-W6.4-P2.54-LS7.6-BL 1
